Fuel Line Part Numbers
Old Mar 18, 2008 | 04:01 PM
drshoebocks's Avatar
I have the EPC installed and running, but can't figure out how to select my truck. I have searched here, other forums, and google and haven't been able to find the exact part numbers, or even a solid diagram.
My truck developed a leak on the hard fuel line going from the fuel tank/pump to the soft line that then leads to the filter. I started to try and patch it, and realized it would be much smarter to replace the entire line. Now that I have bed off the truck, I'm thinking I should do some preventative maintenance on all these lines. I'm trying to find out the part numbers for everything so I can be somewhat intelligent when I order the parts.
93 22RE shortcab 4x4 MT
Any ideas either:
How to select my vehicle in the old EPC japan/europe?
A good place to find part numbers?
Anyone want to just help me out?
Old Mar 19, 2008 | 08:10 AM
Bump for help
Old Mar 19, 2008 | 08:17 AM
Flash319's Avatar
I think you may be out of luck. Brake and fuel lines may not be available for these years trucks. Someone correct me if I am wrong. Why don't you just make your own? You can buy a roll of steel line and a flare tool way cheaper then what 1 line will cost you from the dealer.
Old Mar 19, 2008 | 10:08 AM
dirtoyboy's Avatar
umm maybe try calling the toyota dealer?
Old Mar 19, 2008 | 10:49 AM
Squiddy's Avatar
These lines ARE available for these trucks...I just did gas lines on my '92. Call the dealer, VIN in hand...
Old Mar 19, 2008 | 11:05 AM
pineapple's Avatar
I replaced brake and fuel lines and the fuel pump bracket two years ago. I don't have part #s but the dealer can find them w/ the VIN #. I believe the fuel pump bracket cost $125 then.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Avenged
Jul 9, 2015 07:55 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
