22re charge light
Old Mar 18, 2008 | 08:05 AM
jdcarnathan's Avatar
22re charge light
88 22re that has a newer battery and I just replaced the brushes in the alternator. for some reason the charge light still comes on while driving. anyone have any idea on this thanks
Old Mar 19, 2008 | 05:05 PM
btt someone has got to have an idea
Old Mar 19, 2008 | 05:10 PM
MMA_Alex's Avatar
batt terminals clean? sure you hooked it up right? somethings wrong with the charging system somewhere
Old Mar 19, 2008 | 07:23 PM
DeathCougar's Avatar
maybe the brushes wasn't the problem.
They have internal voltage regulators, and if that went bad, you will get a charge light becuase it will overcharge the system and fry your battery. Get it fixed ASAP.
Old Mar 19, 2008 | 08:05 PM
notanymore's Avatar
if all your wiring is in good order and your terminals are clean and tight then something other than the brushes is wrong with the alt i would guess.
Old Mar 19, 2008 | 08:09 PM
Hayes's Avatar
mine was doing the same thing after I replaced the battery, then I replaced the alternator and all problems are solved.
Old Mar 19, 2008 | 08:25 PM
It can also happen if you forget to put the belt back on.....oopsie
Old Mar 20, 2008 | 02:07 PM
are you able to just change the voltage regulator on the back of the alternator.
Old Mar 20, 2008 | 03:09 PM
possibly, but i have no idea where you would get one.
Old Mar 21, 2008 | 08:20 AM
they actually have a voltage regultor at the stealership and the parts store so is there only one on the back of the alternator itself
Old Mar 21, 2008 | 08:30 AM
rdlsz24's Avatar
Have you had the alternator tested since you replaced the brushes?
Rob
Old Mar 21, 2008 | 08:35 AM
MMA_Alex's Avatar
yeah you should get it tested...if you wanna just throw parts and $$$ at it till its fixed might as well go to the parts counter at the dealership and ask for a whole new alt...
Old Mar 21, 2008 | 12:07 PM
i will go get it bench tested. would they be able to pin point what is wrong with it. is there anything else that could be the cause on it other than brushes or the volt reg
Old Mar 23, 2008 | 06:46 PM
samiam39's Avatar
not sure about the 88 but both the 85 and 86 have a point where the charge wire comes up to the fender and then is connected to the wire harness to go to right side of the truck mine was cruded up also i replaced one altenator and ended up blowing the charge fuse so make sure the fuse is good
Old Mar 23, 2008 | 07:25 PM
mr_schuster's Avatar
Could be one of the copper windings has broken, causing an open circuit in part of the alternators charging field.
Make sure you have 12-12.6 volts going to the alt, the output should be around 14 volts. if its good then your voltage regulator should be too. Buy a cheap ammeter form Northern Tool and wrap it around your neg. cable and turn on everything inside and outside the car that will draw current. Headlights, wipers and ect. Check the amps being pulled by the alt. It should be around 50 to 60 amps, I would think.
Old Mar 26, 2008 | 06:31 PM
battery terminals seemed to be in decent condition but decided to actually change them and voila the charge light no longer comes on. suppose sort of an idiot check but hey its better now.
Sep 4, 2015 09:27 AM
Michael oaks
Jul 27, 2015 11:47 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
