22re charge light
22re charge light
88 22re that has a newer battery and I just replaced the brushes in the alternator. for some reason the charge light still comes on while driving. anyone have any idea on this thanks
maybe the brushes wasn't the problem.
They have internal voltage regulators, and if that went bad, you will get a charge light becuase it will overcharge the system and fry your battery. Get it fixed ASAP.
not sure about the 88 but both the 85 and 86 have a point where the charge wire comes up to the fender and then is connected to the wire harness to go to right side of the truck mine was cruded up also i replaced one altenator and ended up blowing the charge fuse so make sure the fuse is good
Could be one of the copper windings has broken, causing an open circuit in part of the alternators charging field.
Make sure you have 12-12.6 volts going to the alt, the output should be around 14 volts. if its good then your voltage regulator should be too. Buy a cheap ammeter form Northern Tool and wrap it around your neg. cable and turn on everything inside and outside the car that will draw current. Headlights, wipers and ect. Check the amps being pulled by the alt. It should be around 50 to 60 amps, I would think.
Sep 4, 2015 09:27 AM
Odin
Jul 15, 2015 09:28 PM
Sandman
Jul 14, 2015 12:36 PM
