86 22re code clearing?
Old Mar 19, 2008 | 06:32 AM
Junkers88's Avatar
Yes I searched, although I'm not very good with computers and might have missed it.
How do you clear the codes out of an 86 22re? Do I have to pull the battery cable, short the T and E1 terminals, pull a certain fuse?
I'm sorry if this has been covered but I couldn't find it.
Thanks in advance for your time.
Old Mar 19, 2008 | 06:41 AM
4Crawler's Avatar
That is one way, resets the ECU after a few minutes w/o power.
No, that is what reads the codes, but does not clear them.
Yes, pulling the EFI fuse will kill power to the EFI computer and reset it in a few minutes.
More info:
- http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Mar 19, 2008 | 07:27 AM
Junkers88's Avatar
Thanks 4crawler! I've been all over your site for the past few days and must have missed the part about pulling a bat cable.
Since you seem to know a hell of a lot more than I ever will I have a question for you. I have been told to short the T and E1 terminals and start the motor to time it. Is this proper or is it better just to cancel the codes, run it so it can relearn itself and then time it? For that matter since this thing is still surging will the ECU relearn the surge after pulling the cable?
So confusing.......
Thanks again.
Old Mar 19, 2008 | 07:30 AM
rdlsz24's Avatar
Is your timing off?
Rob
Old Mar 19, 2008 | 07:42 AM
4Crawler's Avatar
Clearing the codes is one thing. Setting the timing is another thing, and must be done with the timing jumper installed (5 degrees BTDC). You could check it after driving for a while, but I doubt the ECU re-learning process would change the timing. The ECU basically just re-learns what sort of fuel injector timing adjustments are needed to correct A/F ratios at various throttle and air flow conditions.
For the surging, find out what is causing that and fix it, could be idle speed being set too high or low coolant levels, etc.:
- http://www.4crawler.com/4x4/TLCA_Tru...ech.04.09.html
Old Mar 19, 2008 | 08:00 AM
Junkers88's Avatar
Originally Posted by rdlsz24
Is your timing off?
Rob
It is now. I had to set it way off just to get the dang thing to idle.
Old Mar 19, 2008 | 08:08 AM
Junkers88's Avatar
Thanks again. This is almost exactly what started this entire problem chase that I'm doing except that my tuck failed the HC with a 216 and 218 out of 200 at low and high idle respectively.
"I just had my 85 xcab/efi smogged. It almost didn’t pass. The CO is fine at both idle and rpm. HC’s are way high at idle (220) but fine at rpm. Truck was tuned prior to test and I did an oil change. I also retarded the timing to 2* static. My air/fuel meter suggests the Ox sensor is functioning properly and it’s an OEM sensor. I’m suspicious it’s the CAT.
Over the last six years the HC’s have been climbing suggesting a slow, progressive failure. Other numbers have also risen, but not as rapidly. Do you have any ideas? The only two devices I’m aware of that control HC’s are the CAT and the PCV. I didn’t change the PCV, and don’t suspect it as a problem. As far as NOx, New Mexico doesn’t test for NOx so I have no idea what the number is. "
Oh so I'll put the T-E1 jumper back in there and time it tonight. I've got a timing light so getting back to 5* BTDC will be easy, I've also got a vaccum tester so I'll test the EGR also. So far I've metered the AFM and the TPS as per your site and after a minor adjustment both are well within specs. I've also read about an Auxillary Air Valve so I can check that also. I do not however understand the coolant level idle thing so it's time to hit your site and do some more reading.
Thanks again!
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
nonstop
Jul 24, 2015 06:29 PM
jake_v
Jul 22, 2015 03:17 PM
Fundy Rider
Jul 16, 2015 01:35 AM
