Starter Solenoid Help!!
Old Dec 9, 2009 | 03:25 PM
B4Runner's Avatar
Question Starter Solenoid Help!!
Sorry, this is for my '46 Chevy, not my 4Runner. Help is still greatly appriciated!
Is it bad to have the starter solenoid always on when the ignition is switched? (Click link below for my diagram.) Or should I install a push button that only gives power to soleniod when it's being pushed in? (I have a foot pedal starter, so constant poewr to starter doesnt hurt. Stock with 6V wires straight from battery to starter.) I'm just concerned about the starter being on whenever the ignition is switched. Thank you!
http://i47.tinypic.com/n5272x.jpg
Old Dec 9, 2009 | 03:41 PM
1990yota-pickup's Avatar
you should only get power to the solenoid wire only when the key is turn all the way forward. use a multimeter and check it out.. remember the hot starter lead should come straight from the postive side of the battery and go to postive on the starter which usually on most starter is actually on the solenoid.. make sure the engine is well grouned to the frame. and the battery negative.. its your chocie on how you want to start your truck.. i would just put a inline fuse link it your coming straight from the battery. when u turn the ingition all the way forward the light amp load will engage the relay switch that will usually complete the circut for high amprage load to the solenoid so the starter will engage when the key is all the way forward.
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
