Advice on crankshaft replacement
Old Apr 13, 2014 | 07:20 PM
Paul Haskell's Avatar
I spun a bearing and scratched the hell out of my crankshaft. I'm going to replace all bearings and shaft.
Question. Do the rods need to be replaced as well ? The rod cap with the bad bearing went black.
Do I have to take out the engine to put in a new crankshaft?
Its a 3.0 6 cyl mt
Thanks.
https://www.dropbox.com/s/0ody1b6lha...34498155_n.jpg
https://www.dropbox.com/s/2je0l4z07n...08584899_n.jpg
Old Apr 14, 2014 | 03:50 PM
Logger707's Avatar
You would have to at least separate the engine and trans so my vote would be to pull the motor and at least re-ring and new head gaskets
Old Apr 14, 2014 | 05:00 PM
I think I have to replace the rod. It was pitch black the cap was pretty stuck on so I think it deformed a bit. I JUST rebuilt the head ! I guess I should have looked under first. Lesson learned. I may re-ring too if I can find a cheap set.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Jul 8, 2015 12:05 AM
Vargntucson
Jul 4, 2015 12:15 PM
