Is my transmission bad?
Old Jul 26, 2009 | 12:45 PM
the_supernerd's Avatar
I just got my '92 4Runner going and took it out for a test drive. I picked it up as a fix & sell project so this is the first time I have driven it on the road. It has a 3vze with an auto tranny, which I think might be slipping.
When I am climbing a hill in what appears to be 3rd gear, it seems like the RPMs will increase to about 2800 before it really grabs. It grabs slightly at lower RPM. It does not seem to do that in other gears. All the other gears grab about 2000 - 2200 RPM and shift smooth. When I am coasting down a hill with o/d off, the RPMs fluctuate between idle and 1800. It does not do this in neutral or if I downshift to a lower gear. It is almost like the transmission is grabbing and then letting go. Does this sound like 3rd gear is starting to slip or could there be an easier fix that I am not aware of?
Old Jul 26, 2009 | 12:47 PM
Team420's Avatar
IIRC, with an auto tranny....usually of one gear slips, all gears slip... I am no tranny expert by any means tho.
Old Jul 26, 2009 | 01:05 PM
buckz6319's Avatar
I can email you some troubleshooting information from the Toyota Tech website.I think you have a A340H transmission?..It may help you some
just send me a PM with a email address to send it to
Dwayne
Old Jul 26, 2009 | 02:45 PM
Jay351's Avatar
What does the fluid look/smell like? Black and burnt??
Old Jul 26, 2009 | 04:56 PM
I was reading about it, and I think the torque converter is not grabbing like it should. When it is locked, the slipping does not seem to happen, meaning the transmission should be ok. The fluid is not black, but it is getting there. It does not smell burned. Do you think it could just need new fluid? Maybe it is just old and does not have the same viscosity it should have?
Old Jul 29, 2009 | 10:40 PM
I changed the tranny fluid and it did not seem to make much of a difference. Does anyone know what the stock stall speed of the torque converter is suppose to be?
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
