intank fuel pump connecter
Old Nov 13, 2012 | 10:46 AM
Fierce Legend's Avatar
Theres a connector that plugs into the fuel pump inside the tank. I took it out to replace it and noticed that in the plug that the little tab that's bent over inside the plug to apply pressure onto the tabs inside the pump it slides onto.
One of those bent tabs inside the plug was proken off and was causing my truck to crap out and I would kick the tank and it would be ok again.
I called Toyota I cant just buy the plug I have to buy the entire fuel pump bracket for 130 all because of a stupid little plastic plug that cost's 10 cents.
Any idea's on how I can find a plug that will fit the fuel pump? I could drill out the rivets and replace them with bolts and then weld the bolts so they cant back off and arc anything out. I just need the plug with some nice long wires coming out of it.
Old Nov 13, 2012 | 02:00 PM
I went to lordco and found a 2 wire ford plug of some sort that fits the electric fuel pump inside the tank. I just cant remember wich tab on the fuel pump is negative and wich one is positive.
Looking at the pump with the output on top wich tab is the negative and wich is the positive on the fuel pump?
Old Nov 14, 2012 | 06:12 AM
uncleblues's Avatar
don't look at the pump
find a wiring diagram-the WIRES are color-coded
on my truck the power from the COR is blue, and ground wire is white/black stripe
sandyota
Feb 4, 2021 11:16 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Fundy Rider
Jul 16, 2015 01:35 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
