help please
Old Nov 17, 2012 | 06:36 PM
wolf28's Avatar
Exclamation help please
well i switched the bulbs behind my gauge cluster and now my blinkers wont work and second of all i broke my dimmer switch need help in which direction to look in
Old Nov 17, 2012 | 06:38 PM
StewsRunner's Avatar
$20 says you forgot to plug in the hazard harness. . . I've done that
Old Nov 17, 2012 | 06:45 PM
wolf28's Avatar
congrats u are correct i never plugged it in
Old Nov 17, 2012 | 06:51 PM
wolf28's Avatar
i feel so stupid now
Old Nov 17, 2012 | 06:54 PM
Don't know about the dimmer though
Old Nov 17, 2012 | 06:58 PM
wolf28's Avatar
no it broke the circut inside so i need to get another one
Old Nov 18, 2012 | 02:15 PM
Terrys87's Avatar
In my area a combo switch runs about $40 from the boneyard. I would suggest getting one from there and before putting it in, clean the contacts on the switch assembly to head off the problem of bright lights not working. The contacts just need a quick cleaning. I have it listed on my 88 Runner build thread on the first page. You will need to rent a wheel puller from a parts store.
Old Nov 18, 2012 | 02:39 PM
lobukbuild's Avatar
or bring a friend.loosen steering wheel nut a few turns, one guy pulls up on wheel as hard as possible and the other guy wacks the nut with a hammer.should pop up easily.
Old Nov 18, 2012 | 04:24 PM
scope103's Avatar
Originally Posted by lobukbuild
...the other guy wacks the nut with a hammer ....
You'd hit the steering column with a hammer just to save $20? http://www.autozone.com/autozone/acc...uller/_/N-2652 (Actually, to save nothing; I think Autozone loans these out for free. )
Please, easy on the hammering. The steering column is designed to "telescope" in a collision, and you don't want to get that mis-set.
Old Nov 18, 2012 | 04:27 PM
wolf28's Avatar
ok im confused i dont nee a high low beam dimmer i need the gauge cluster dimmer
Old Nov 18, 2012 | 05:00 PM
brianh699's Avatar
You need a rheostat (Toyota part name) no need to pull steering wheel, but if you can find a used one it will save you money. They're spendy new from dealer.
Old Nov 18, 2012 | 05:18 PM
wolf28's Avatar
yea i broke that and need to find a new one
Old Nov 18, 2012 | 06:30 PM
brianh699's Avatar
Not sure what year your pickup is but judging by your avatar I think this is the part. It's $111 from tituswilltoyota.com, but it's used on a few models I'd check the classifieds here for a part out. Part 84119‑04010 (RHEOSTAT, LIGHT CONTROL) was found on the following models:
Date range Model Frames/Options Found in diagram
02/1992-12/1994 TOYOTA 4RUNNER TRUCK RN101,110,VZN100,110 84-01: SWITCH & RELAY
01/1995-08/2004 TOYOTA TACOMA RZN161,171,VZN160,170 84-01: SWITCH & RELAY 09/1991-12/1994 TOYOTA 4RUNNER TRUCK RN80,90 84-01: SWITCH & RELAY
01/1995-08/2004 TOYOTA TACOMA RZN140,150,19*,VZN150,195
Old Nov 18, 2012 | 06:54 PM
wolf28's Avatar
its a 89 someone has a 92 but he dint specify if it was a truck or not
Old Nov 18, 2012 | 07:41 PM
brianh699's Avatar
If it's an 89 that's better lots of interchange on that part.
Part 84119‑32090 (RHEOSTAT, LIGHT CONTROL) was found on the following models:
08/1987-05/1992 TOYOTA COROLLA AE92,95 84-01: SWITCH & RELAY
08/1987-08/1992 TOYOTA COROLLA AE92 84-01: SWITCH & RELAY
09/1990-07/1993 TOYOTA COROLLA AE95 84-01: SWITCH & RELAY
08/1987-07/1989 TOYOTA CELICA ST16* 84-01: SWITCH & RELAY
08/1988-05/1991 TOYOTA CAMRY SV2*,VZV21 84-01: SWITCH & RELAY
07/1988-08/1991 TOYOTA CAMRY SV2*,VZV21 84-01: SWITCH & RELAY
06/1989-06/1991 LEXUS ES250 VZV21 84-01: SWITCH & RELAY
08/1988-10/1995 TOYOTA 4RUNNER TRUCK RN10*,110,13*,VZN10*,110,13* 84-01: SWITCH & RELAY 11/1995-07/2002 TOYOTA 4RUNNER RZN18*,VZN18* 84-01: SWITCH & RELAY
08/1988-10/1995 TOYOTA 4RUNNER TRUCK RN8*,90,12*,VZN85,9*,VZN120 84-01: SWITCH & RELAY 08/1992-06/1998 TOYOTA T100 RCK10,VCK1*,2*
Old Nov 21, 2012 | 02:03 PM
lobukbuild's Avatar
yes hit the column with a hammer done it a thousand times at work never damaged a one. we are talking removing a steering wheel and nothing to do with the crush zone on the shaft.this would be useful to some on that does not have access to a puller.
Old Dec 4, 2012 | 04:09 PM
wolf28's Avatar
a kid has a 92 pick up near me for part and has the rheostat how much should i offer him for it
Old Dec 5, 2012 | 03:17 PM
Sturmcrow's Avatar
My rule of thumb is to pay not more than half of the new price for used parts. So, if the part is $111, I'd offer him $20-25 and not go over $50.
Old Dec 17, 2012 | 06:35 PM
wolf28's Avatar
well a guy i work with has a 91 toyota corolla wagon seeing if i can get it off his car
