R150 Trans Pulling Hard Left in 4WD
Old Dec 20, 2013 | 08:08 AM
Austin Marr's Avatar
Whats up guys! I got a 93' ex cab 3.4 swapped thats pullin hard left when I am in 4WD. I have confirmed that both hubs are locked. I am thinking that over time, the abuse that i've put on the t-case mount and then the added torque of the 3.4 may have exhausted the t-case mount causing the t-case to twist a little more then usual which in turn torques the whole front end to the left? Thoughts? Merry Christmas
Old Dec 20, 2013 | 08:38 AM
millball's Avatar
Probably not a transmission problem.
Much more likely in the front axle somewhere.
Jack her front wheels up and check for sticking brakes and smooth rotation of the axles.
Maybe some front suspension parts are shifting and binding when torque is applied in 4wd.
Old Dec 20, 2013 | 08:56 AM
jtinco's Avatar
Even if your transmission and tcase were twisting to the side you wouldn't get a pulling because your driveshaft would simply compensate for the new angle. Sounds like a problem with loose or worn out parts (bushings or tie rods).
Old Dec 20, 2013 | 09:04 AM
I am getting ready to do a whole front and overall including bushings bearings and a 5 inch lift so I think I might buy the differential bushings as well
Old Dec 20, 2013 | 09:23 AM
And ball joints. Never done the tie rod though
Old Dec 20, 2013 | 10:43 AM
JonnyBoy's Avatar
Might not hurt to do the differential bushings, though I've never heard of them being a problem. It'd go with your whole new front end, anyhow.
As far as the pulling, it's more than likely just alignment. It doesn't take much misalignment to make it pull one way or the other. Mine is aligned enough to make the tires wear evenly, nothing odd other than the normal front end cupping if you don't rotate the tires on time. It still gets pushed to the left by the front right tire, though that could also be a worn idler arm. Also, is this on pavement it goes to the left? Mine doesn't in dirt/snow because there's enough slip in low traction environments.
Old Dec 20, 2013 | 10:55 AM
Snow, pavement, anywhere. I've chatted with WabFab regarding this and he says that he thinks my passenger hub is not locking all the way. Going to stick with the front and overhaul since I've already ordered all the parts and was planning on doing it anyway
Old Dec 20, 2013 | 03:35 PM
RJR's Avatar
RJR
If you have an open front diff, an unlocked hub will just mean no 4wd at all. It won't cause it to pull one way or the other. If the front diff has a locker, then an unlocked hub on the left wheel will cause it to pull to the left on acceleration, and to the right on deceleration.
Old Dec 20, 2013 | 03:40 PM
I disagree. Same concept as if you stuff your passenger side tire in your fender well, the tire on the other side is still going to spin regardless and visa versa.
Old Dec 20, 2013 | 03:43 PM
JasonYota's Avatar
RJR was saying if your front diff is open, with only ONE hub locked and the other unlocked NO power gets to the front wheels
Old Dec 20, 2013 | 03:44 PM
JasonYota's Avatar
You have a front locker correct? You can just lock your passenger side hub only to see if the hubs is engaging.
Old Dec 20, 2013 | 03:48 PM
Open diff. And i dont think thats how the diff's work.....?
Old Dec 20, 2013 | 03:51 PM
JasonYota's Avatar
What do you mean how the diffs work? All a diff does is transfer power
Old Dec 20, 2013 | 03:59 PM
Yes i know that. It just doesn't make sense how if only one hub is locked that automatically means no power is going to any of the tires regardless if the other side is locked. If the other hub is locked, that side should at least get power right? I am not sure how the front diff's work or what happens when only 1 hub is locked and the other isn't but doesn't each hub work independently? or do they really have to work together to get power to the front at all? I'd be curious to see how it works (visual learner here). Thanks for the input
Old Dec 20, 2013 | 04:01 PM
scuba's Avatar
Wait. Is the steering pulling or is the the whole engine, trans, and transfercase actually rotating which is noticeable by watching the shifters?
If its just rotating, that's normal. It's called driveline torque. There's a reason your engine and transmission is mounted on rubber. It's so it can move like it needs to.
Old Dec 20, 2013 | 04:05 PM
JasonYota's Avatar
An open diff sends power to the side with least amount of resistance. Ever seen a 1 wheel burn out? There are some good videos on YouTube how a diff works.
Not sure what would cause your truck to pull to the left in 4wd if you have a open diff. Are all of your tires the same size? Same tire pressure?
Old Dec 20, 2013 | 04:07 PM
scuba's Avatar
Power travels through the path of least resistance.
Think about it like this.
4 WD. Drivers side hub locked and passenger side unlocked. Where is the path of least resistance? The side unlocked hub because that shaft isn't trying to turn the tire and wheel.
The actual shaft on passenger side still spins but since the hub is unlocked you won't go anywhere.
This is the reason we put lockers in our trucks.
Do some reading.
http://www.howstuffworks.com/differential.htm
Old Dec 20, 2013 | 08:16 PM
Ya I get it now. Tires same size/brand etc. I'm meticulous with that kind of stuff. The little stuff like this bothers me and I want to fix it if possible
Sent from my iPad using YotaTech
Old Dec 20, 2013 | 08:21 PM
combatcarl's Avatar
Worth watching.
Sent from my NSA screened iPhone
Old Dec 20, 2013 | 09:17 PM
JonnyBoy's Avatar
Does it only do it when accelerating, decelerating, or both? It only does it in 4wd, so just for s&g's, how did you confirm your hubs are locked? What condition are your cv's in? When was your last alignment, brake service, tire rotation, etc?
