Whining radiator and above average temperature.
Old Jan 4, 2014 | 12:30 PM
SqWADoosh's Avatar
So my good ol' 88 has a new problem for me to figure out. She has a radiator whine after driving (or idling) for 10-15 mins. Also the temperature has raised from where it normally sits. There is a smell of antifreeze that I'm pretty sure is coming out of the bleed tube attached to the overflow tank. I haven't drove it for an extended amount of time to see if it completely overheats due to being scared of it getting stranded. The only work I've done on it recently is change out my CAT and an oil change. Any ideas guys on where I should start on diagnosis? She has a 22re. Thanks fellas as always.
Old Jan 4, 2014 | 12:39 PM
ksti's Avatar
Check that radiator cap, could be the culprit.
SqWADoosh's Avatar
Should I just replace it and see if it fixes my issue? I mean its cheap right. I'll start with that. Thanks. Anybody else?
Old Jan 4, 2014 | 01:44 PM
Blueman's Avatar
Yes, I'd just replace the cap for your initial debugging:
Amazon.com: Stant 10227 Radiator Cap - 13 PSI: Automotive Amazon.com: Stant 10227 Radiator Cap - 13 PSI: Automotive
Mine original cap wasn't leaking, but it wasn't holding pressure, and yours might just be tired and ready for renewal, especially if it's still original.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
mreagen
Oct 5, 2015 04:27 PM
scott90
Oct 4, 2015 09:21 AM
Matthew Perez
Sep 28, 2015 05:43 PM
