Vaccum and Ignition timing questions ?
Old Dec 29, 2013 | 02:48 PM
Vmax540's Avatar
Out of truck rebuild and I do not see where this vacuum port (with black cover) hooks up. I have a 1989 which only has 3 ports instead of the 4 on this a 1995. Also, when setting then ignition timing the manual says to hook up an SST to terminals TE1 & E1 of the DLC is this simply a jumper ? Thanks for any help Chuck S.
Attached Thumbnails Vaccum and Ignition timing questions ?-001.jpg   Vaccum and Ignition timing questions ?-004.jpg
Old Dec 29, 2013 | 04:51 PM
Redeth005's Avatar
Hi Chuck. I have an 1989 4runner with the 3.0 V6. I had lots of problems with my vacuum hoses when i got the truck and i finally got to the bottom of how everything is hooked up. I Hope these diagrams and videos help you out in that part. As for the 4th port that you have plugged I have absolutely no idea where that one goes lol Mine doesn't have that one.
1)
2)
3)
Im not much help with the other question you had though. Good Luck
Old Dec 30, 2013 | 05:21 AM
Vmax540's Avatar
Thanks Redeth005 !
Old Dec 30, 2013 | 07:12 AM
RJR's Avatar
RJR
The "SST" is indeed simply a jumper. Lots of folks use a paper clip. Any short piece of wire will do.
Old Dec 30, 2013 | 08:41 AM
Redeth005's Avatar
Ohh that's what he meant. Lol yea I always use a paper clip or a small speaker wire to jump the terminals.
Old Dec 30, 2013 | 08:54 AM
Vmax540's Avatar
Cool !
Old Dec 30, 2013 | 02:32 PM
Bills86e's Avatar
Yes, a jumper. If you pull the 15A EFI fuse for 30 seconds will turn the check engine light off.
Since the check engine light is on, there are code(s) stored in the ECU. To retrieve the codes
you need to find the diagnostic connector under the hood. Flip the cap open and there is a label
that corresponds to the terminals in the connector. You want to take a piece of wire or paper
clip and jump TE1 to E1. Turn on the ignition and the check engine light will flash the codes.
Write down the numbers and match it to the list of ECU codes.
I guess this is where we're going?
Old Dec 31, 2013 | 04:12 AM
Vmax540's Avatar
No check engine lights, yet..... just setting the timing !
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Avenged
Jul 9, 2015 07:55 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
