door issues
Old Dec 15, 2013 | 05:28 PM
kawasakilewis's Avatar
door issues
hi all, i have an 85 xtra cab. when i bought it the passenger door handle on the inside you would have to pull it kindof hard and repeatedly to get it open, now theres times where it wont open from the inside. my drivers door just started today where i have to pull it repeatedly from the inside sometimes and i looked inside an cant really see a problem, is this a common issue? i searched snd cant really find much on it
Old Dec 16, 2013 | 03:53 AM
Yamiryder's Avatar
scrap it
Old Dec 16, 2013 | 05:52 AM
nmtoy's Avatar
Remove the door panel and put a little more bend in the rod that goes from the handle to the latch. I just had to do this to my truck.
Old Dec 16, 2013 | 10:29 PM
Terrys87's Avatar
I have seen worn door hinges cause similar problems as you are mentioning as well. It lets the door sag and my guess is the rod is not pulling far enough to release the latch.
Old Dec 17, 2013 | 07:16 AM
nmtoy's Avatar
Good point Terry. I am sure my truck resembles that remark....
Old Dec 17, 2013 | 07:47 AM
Stevesk88's Avatar
^THIS.
Use a vice grip and support it and just twist to make a small bend that wont unbend.
Old Dec 17, 2013 | 09:04 AM
Gamefreakgc's Avatar
x2. Removing the door panel isn't too hard. When removing the window handle (if it's not auto window) you'll need to remove the clip by sliding in a rag and popping it out.
See page BO-6: http://personal.utulsa.edu/~nathan-b.../3frontdoo.pdf
Old Dec 17, 2013 | 01:31 PM
it is an auto window believe it or not
bigjstang
Jun 2, 2025 03:56 PM
westonian18
May 1, 2020 06:38 AM
jasonty
41
Dec 23, 2018 01:00 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
94yotaky
Jul 23, 2015 07:50 AM
