need injector help 86 22re
Old Aug 5, 2006 | 03:21 PM
rwhite's Avatar
I have an 86 22re with a bad injector. I've tried movig the injector to a different hole and the problem follows. The engine was a swap from a 92 but the top end (fuel rail, manifolds ect.) is from the 86. My question is: I have the entire fuel rail with injectors from the 92 but the connectors are different. Is there any way to swap a single injector, or entire fuel rail? Can the connector be swapped? I was wondering if I cut the wires on the 86 injector could I splice in the 92 injector? Any help is appreciated.
Old Aug 5, 2006 | 03:23 PM
rwhite's Avatar
Oh yeah, the truck is an 86
Old Aug 6, 2006 | 04:22 AM
rwhite's Avatar
Well, I tried the splice and it worked. Now if anyone can tell me if there is a reason I shouldn't have done this it would be appreciated. It seems to run good.
Old Aug 7, 2006 | 04:29 PM
rwhite's Avatar
Bump, ANYONE KNOW?
Old Aug 8, 2006 | 06:01 AM
Flash319's Avatar
No that will work. Just make sure the connection is good and covered well.
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
Tacoma1313
Aug 17, 2015 05:44 PM
