How to tell if rear leaf springs are worn - YotaTech Forums
LinkBack Thread Tools Search this Thread
Old 08-11-2006, 08:13 PM   #1
T_BONE's Avatar
Was just wondering if there was any way of telling if the rear leaf springs were worn. The ass end of my toy is sagging a little bit and was wondering if the leaf springs were the problem or something else. The truck is a little lower in the rear.
T_BONE
T_BONE is offline   Reply With Quote
Old 08-11-2006, 08:25 PM   #2
rebult junk's Avatar
are they flat when the turck is on the ground
rebult junk is offline   Reply With Quote
Old 08-11-2006, 09:57 PM   #3
humanoid's Avatar
They're supposed to have a slight upward arch if you look at them from the side. If you don't see any arch, like mine, your springs are worn and you either need to get new leaf packs or have them re-arched.
humanoid is offline   Reply With Quote
Old 08-12-2006, 09:26 PM   #4
CoedNaked's Avatar
Is your rear end sagging?
CoedNaked is offline   Reply With Quote
Old 08-29-2006, 06:32 PM   #5
T_BONE's Avatar
Yeah, it is. I had someone look at the leafs and they are all good. They seem to think the tortion bars were tweeked b-4 I bought it. How do you tell?
T-BONE
Old 08-29-2006, 07:02 PM   #6
Saint_Berzerker's Avatar
If your rear is ok and the front is jacked up to much, just loosen (ccw) the torsion bars a little bit at a time to lower the front. I'd loosen 2 or 3 turns at a time and check.
Watch your bumpstop clearance and make sure you don't get any less than an inch or so. If you are already at an inch or less then I'd say your rear has to be sagging.
Saint_Berzerker is offline   Reply With Quote
Old 08-30-2006, 03:23 PM   #7
T_BONE's Avatar
Yeah, I just looked at the bump stops and the upper bump stop has about an 8th inch clearance while the lower has a couple of inches. If I were to change this will I need a front end alignment again or not?
Peace,
T-BONE
By-the-way, thanks for the replies.
Old 08-30-2006, 03:27 PM   #8
would puting an AAL help at all? Because mine a totaly flat now
Firefightertaco is offline   Reply With Quote
Old 08-30-2006, 03:33 PM   #9
T_BONE's Avatar
I guess the tortion bars being cranked on explains why my rig beats the hell out of me in the back country off-roads. lol
T-BONE
Flying91's 1991 4runner LOWEST SAS 30" tires Flying91 86-95 Trucks & 4Runners (Build-Up Section) 39 02-03-2017 05:37 PM
Sloppy suspension 99 tall t4r Yotadawgjr 95.5-2004 Tacomas & 96-2002 4Runners 10 08-23-2015 10:51 AM
FS[GreatLakes]: Toyota collection part out 88sasturbotoy Axles - Suspensions - Tires - Wheels 2 08-11-2015 01:56 AM
FS[SouthEast]: 99+ center console, rear air deflector, lift spacers, steering wheel terminator Misc Stuff (Vehicle Related) 3 07-27-2015 07:13 PM
94' Pickup ZUK Mod - What Springs? Nickdigg 86-95 Trucks & 4Runners 1 07-07-2015 06:04 AM
Tags
52, 56, bad, badhow, changing, check, leaf, leave, rear, sagging, spring, springs, srpings, truck, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
