separating front rotor from axle hub.
Old Aug 5, 2006 | 12:46 PM
timmie's Avatar
Long time lurker, first time poster.
I am attempting to replace the front rotors on my 1993 4wd 4Runner. I have removed the rotor and hub assembly from the spindle but am having a bear of a time getting the two separated. I have searched the posts and not found the answer i am looking for so hopefully a kind soul out there will be able to help me out.
The Haynes manual i have makes it look like you lay the rotor side down and bang the end of the bolts with a hammer and punch. I tried turning the bolts and they won't budge so maybe there is merit to this banging method?
-tim
Old Aug 5, 2006 | 12:58 PM
VA_Yotaman's Avatar
I just did this a few months ago. I soaked all the bolts in PB Blaster, and then placed the rotor in a vise. I used a 1/2 breaker bar, and they came right off. Having a vise is the best way, because there is really no good way to hold the rotor still. Even after I got the bolts out, I had to use a big chisel to seperate the hub and rotor.
Old Aug 5, 2006 | 01:05 PM
timmie's Avatar
Thank you for the quick response VA_Yotaman. I will let them soak while i eat a late lunch and then I will crank on them.
Old Aug 5, 2006 | 04:31 PM
TNRabbit's Avatar
...an impact wrench helps somewhat....but I still had to beat the CRAP out of mine to get them off.
Old Aug 7, 2006 | 02:52 AM
91 4Runner's Avatar
I just did both of mine and I found that just sticking the hub upside down in the rim is enough to hold the hub to loosten the bolts (for both loostening and tightening) And I used an impact socket on a breakerbar. You may find that you need to put a bit of weight on the tire. Once they are loose remove with a ratchet. Then you may need a cold chisel or standard screw driver and hammer to get the hub/rotor to separate working around the outside bit by bit... Hope this helps....
Old Aug 7, 2006 | 01:02 PM
timmie's Avatar
Victory is mine.
Thanks to the help of everyone on this board i successfully swapped out my rotors and pads. Yippeee.
Praise be to the internet and the ease of getting help when it is needed. How did people ever get anything done before Al Gore invented this fine instrument of knowledge distribution?
-tim
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
deepmarsh
Aug 6, 2015 03:44 AM
PlayAwhile
Jul 20, 2015 11:36 AM
toyoda8488
Jul 5, 2015 10:18 PM
