3VZE Fan Shroud
3VZE Fan Shroud
Does anyone here run without their fan shroud on the 3VZE?
The reason I ask is mine is broken and I'm disinclined to replace it. Motor Trend channel did a test of different types of fans to see how much horsepower they used. Of course the clutch type fan was the best; used the least horsepower, but they also tested removing the fan shroud. That increased available horsepower also. I'm all for gaining little bits of hp everywhere I can.
I can see that in worse case scenarios, like stuck in heavy traffic on a hot day with the AC on you'd want that fan shroud pulling every bit of air through the radiator. But I live in the temperate Pacific Northwest and I don't drive in traffic.
What do you think?
What do you think?
In the 15 years I've owned my truck it has never gotten hot even going up steep grades in 100 degrees plus temperatures. What I have read is that if you are going at least 35 mph the fan is not really necessary. I wouldn't bet the farm on that statement but we aren't talking about eliminating the fan; just the shroud.
Mak914rnr ran without a fan shroud here in CA and was constantly plagued by overheating problems and finally popped a head gasket. dont take the risk. if you dont want to run a shroud, get rid of the fan altogether and go electric. aint worth a grand in repairs on the off chance you damage something.
