tail light fuse
Old Apr 21, 2017 | 04:39 PM
ianD's Avatar
tail light fuse
1991 22RE pickup, I was driving to work in the morning and the dash lights went out suddenly. Found the tail light fuse had blown, replaced it and it blew again as soon as I turned the lights on. After some forum searching this was the only thread I found that was any use https://www.yotatech.com/forums/f116...opping-215302/
I disconnected the rear harness under the passenger seat but the fuse still blows. I haven't messed with any of the wiring in several months and even then it was only to replace the O2 sensor so I don't think that has anything to do with it. Is there anywhere in particular I should start looking or is it pretty much a shot in the dark? I'm pretty bad with electrical so any advise would be appreciated, thanks.
Old Apr 22, 2017 | 02:41 AM
wyoming9's Avatar
Red face
Shorted Tail light relay ?? I would check this first I am guessing it has one
I would check the wires around the front marker lights looking for possible shorts
Then check the Rheostat that might have shorted
Aftermarket Radio at all??
Any of the dash lights or wiring in the light circuit with the rear light harness disconnected
Old Apr 22, 2017 | 07:13 AM
ianD's Avatar
Where is the tail light relay located?
Old Apr 22, 2017 | 12:36 PM
wyoming9's Avatar
Red face
My best guess would be in the area of the fuse panel behind the left kick panel
Above the fuses
Old Apr 22, 2017 | 06:46 PM
RAD4Runner's Avatar
Originally Posted by ianD
I disconnected the rear harness under the passenger seat but the fuse still blows. I.
Originally Posted by wyoming9
...I would check the wires around the front marker lights looking for possible shorts...
Start with these ^^^ two first. Inspect tail light and clearance marker sockets and wiring for short to body ground. You do not need to be an electrical expert to see if a wire is touching body metal.
