22RE Mystery engine trouble!!
Old Aug 4, 2008 | 10:19 PM
Skinamer's Avatar
My truck has been running perfect ever since I bought it a year ago. But recently it is giving me some trouble. While drivivng it last week it suddenly died and i pulled off the road. When I tried to start it up it would idle very rough and it would die when I push the gas pedal. After about 10 times of re-cranking, it ran fine and I drove it home. Well I drove it around for over a week with no problems, but today it did it again. I cant seem to figure out what is doing it. Today, it wouldn't crank a few of the tries and when it did it would idle very rough. Then all the sudden it cranks up normally again and I drive it home. Only this time i'm not going anywhere until I figure out whats going on. Any ideas? Thanks.
Old Aug 4, 2008 | 10:21 PM
just a 22re's Avatar
check your fuel pressure! sounds like your pump is going bad!
Old Aug 4, 2008 | 10:30 PM
Skinamer's Avatar
I replaced the pump, among many other things, when I bought the truck, but i didnt flush the tank out.
This is what I had done when I bought it:
Timing chain kit
Head gasket
Water pump
alternator
battery
plugs and wires
distributer cap
Fuel pump and filter
Radiator
Throttle position sensor
Old Aug 4, 2008 | 10:31 PM
then you should try and test the maf and the tps they both go in runing the fuel pump! make sure there both to spec!
Old Aug 4, 2008 | 11:00 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
maybe another fuel filter
Old Aug 5, 2008 | 04:28 PM
84sr5yoty's Avatar
Also check circuit opening relay (fuel pump relay) and main EFI relay AFTER the engine starts acting up. Both relays become intermittent before completely crapping out.
Old Aug 8, 2008 | 02:59 AM
ssupercoolss's Avatar
i had the afm sort of do the same thing on my truck. all of a sudden driving down the road the motor would just fall on its face, then pick up again. check your connections at the afm. clean them up some if they look a little gross.
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Yota.Jay
Jul 23, 2015 08:08 PM
