Fluctuating oil psi
Old Jun 27, 2011 | 11:50 AM
stealth7's Avatar
Fluctuating oil psi
I just picked up a really nice 1992 4runner and it runs and drives fine the only thing is the oil psi will go from hi to low and back to hi and it is just all over the place. I guess what I am saying is I am new to toyota's and I was wondering if the sending unit is a good place to start. It has the V6 engine in it. Any help would be great
Old Jun 27, 2011 | 11:57 AM
waskillywabbit's Avatar
Typical normal. Checked the dipstick?
:wabbit2:
Old Jun 27, 2011 | 12:20 PM
stealth7's Avatar
Yes that was the first thing I did
Old Jun 27, 2011 | 12:46 PM
tardman91's Avatar
They all do that. As long as you have the right amount of oil in there I wouldn't worry about it.
Old Jun 27, 2011 | 06:20 PM
Yota2k55's Avatar
yes i have to agree. Mine does the same and i too was worried at first. But then i realized, Ive had a mazda that did that, a ford that did that, a blazer that did that and a few others too
Old Jun 27, 2011 | 07:02 PM
xxxtreme22r's Avatar
Yup normal. The more mileage on the engine the more fluctuation you will see. Plus the OEM senders aren't the most accurate thing in the world either. Mine jumps from just below 1/4 at times at idle and hot to about 1/2 way when driving. And this is on a rebuilt engine with about 15 K or so on it. But of course it's also a 22r not e 3.0. But they all do the same thing for the most part. Unless it's running at 1/4 when hot and driving then you have nothing to worry about.
Old Jun 27, 2011 | 08:05 PM
stealth7's Avatar
thanks that makes me feel better about driving it.
Old Jun 27, 2011 | 09:39 PM
73pinto's Avatar
mine did that and started knocking although the engine had a fire before i got it
Old Jun 27, 2011 | 10:17 PM
Mr.Utah's Avatar
Begging the question, what is a best way to monitor pressure? Mechanical gauge or electrical sending unit?
We all know the idiot lights are SCARY!
Old Jun 28, 2011 | 05:59 AM
Team420's Avatar
u cant beat the mechanical guage.....
My $0.02.... if the guage goes all the way to high, I would be concerned... That could be due to sludge build up in the motor, not allowing oil to flow properly.... Not sayin this IS your problem, just something u might wanna check out with a mechanical guage.... Too much oil pressure, is just as bad, if not worse than too little....
Old Jun 28, 2011 | 06:19 AM
good catch team420. I guess HI unless using 3/4 to full is a relative term all of us had missed.
Old Jun 28, 2011 | 09:04 AM
TNRabbit's Avatar
I'm guessing this has more to do with a SHORT in the wiring to the oil pressure sending unit than it does fluctuations in the oil pressure. That was my problem. Soldered it back in place & no problems.
Old Jun 29, 2011 | 06:36 AM
Team420's Avatar
Most likely true.... But, better safe than sorry, I have seen numerous engines seize with super high oil pressure, due to sludge, or clogged oil passages for some reason or another.... Get the mechanical guage on it, and go from there....
Old Jun 29, 2011 | 08:16 AM
sb5walker's Avatar
If you really want to clean out a motor, run Red Line 5W-30 for 5-6k miles, and use a couple Purolator PureONE PL20195 filters. Change the filter at 2k miles (and top off oil since you'll lose some in the filter).
Red Line oil is a Group V synthetic ester, which removes sludge like nothing else. Esters are highly polarized long chain molecules, which attach to dirt just like detergents.
http://www.summitracing.com/parts/RED-15304/
The PureONE filter is probably the best filter available for our motors - filters smaller particles and has great flow. Advance Auto carries them, or you can get them from amazon.
http://www.amazon.com/Purolator-PL20...dp/B000E8T83S/
x2 on cleaning up the sender connector.
Old Jun 29, 2011 | 08:03 PM
stealth7's Avatar
Thanks for all the info I am going to put a mechanical guage on it and see how it looks.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
calderp
Jul 27, 2015 09:58 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
horunner1x
Jul 10, 2015 06:33 AM
