Faulty chain tensioner?
I think my new chain tensioner is faulty....
I just did a headgasket and timing kit and ever since its had this weird rattle...
I've done numerous valve adjustments and replaced the adjusting screws to no avail.
The noise is only there when the engine has warmed up. NO RATTLE at startup or for the next few minutes. Its loudest when driven for a while and ONLY makes it at idle.
The noise was very inconsistent at the beginning...It would be quiet for days then suddenly appear for a day then gone again. Its got more and more consistent and now its always there at idle when warm.
Stethoscope puts the noise at the timing cover....I think....
With the valve cover off the chain looks tight. Guides look new and fine...
Oil pressure at idle is high...almost 30 psi...
The oil pump bolt is NOT interfering with the tensioner...I checked that already
The only thing I can think of is a faulty tensioner??
any ideas??? Anyone had a bad tensioner do this?
put the stethiscope on the top of the valve covor, maybe the vavles are colliding with the vavle covor.
the chain tensioner is oil pressure operated i beleive, did you drop your oil pan and clean it out? (though 30psi should rule that out)
before you put the tensioner on did it seem like the spring was working? (ive always squeezed mine beforehand to make sure it works)
Great question. That could be the problem right there.
If I was going to take the timing cover off, I would probably go ahead and replace the chain and sprockets and tensioner. It took me an entire day to get all that stuff apart, so it's not something I'd want to do again anytime soon.
I would definitely rule everything else out first though, because you don't wanna do a job like that unless you're pretty damn sure it's the tensioner and not something else.
FSM is 14ft/lbs
If the VALVES are hitting the valve cover I have waay bigger problems.
As stated I have done numerous valve adjustments, there is nothing contacting the valve cover, and I have not overtightened it.
About six week ago I replaced the whole timing assembly(chain, sprocket, tensioner)
and yes the tensioner appeared to be working.
Oil pan is clean.
Oil pan is clean.
manufacture of parts
hey there, i have the exact same problem. i used a cheap set of parts, Federal-Mogul, and get the exact same symptoms. i may try factory replacement parts, and hope this will solve the problem
thralldad - What happened with yours?
That Loctite might be a good idea. I was thinking about doing that with mine (after I got it all back together, hah). Hopefully the tensioner bolts will stay put with 15 ft lbs and no loctite. If I do it again I think I'll use the Loctite for peace of mind.
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
charlie_fong
Sep 27, 2015 10:06 PM
