Heater Control Issues
Old Jul 12, 2011 | 11:03 AM
AbeWhat's Avatar
86 P/U, 22r, A/C,
So for the past few weeks I only had OFF-LOW-MED controls, no HIGH. When I turned it to HIGH it would just cut off, nada. So I just dealt with it. The other day it stopped working on all speeds.
I then searched/researched and got familiar with what I was looking at. I checked the resistor (1st) and heater switch plug (2nd) according to the 85 FSM. The resistor was slightly corroded,and one of the coils was eaten through. I took a single thin strand of copper wire, hooked it on that coil and I re-installed it. Then the controls went back to OFF-LOW-MED, not HIGH.
I then checked the plug, it showed a problem with the HIGH setting, I don't remember which #'s didn't have continuity off the top of my head. Basically, I think I need to replace the 4 position switch in the dash.
All this happens with A/C on or off, no difference.
Does this sound right? How the hell do I get that thing out of there? It's pretty tight. Thanks for any insight.
Old Jul 12, 2011 | 12:56 PM
snobdds's Avatar
This should help you out with your problems..
https://www.yotatech.com/forums/f116...ctures-227171/
Old Jul 13, 2011 | 09:28 AM
AbeWhat's Avatar
Nice! I haven't seen this one yet. I'll pull it out, I'm not sure about fabbing up a whole new copper piece. We'll see. Thanks.
-Abe
Old Jul 13, 2011 | 02:22 PM
myyota's Avatar
It sounds like you need a new fan switch. The part that sucks is that you have to pull the whole dash a part to change it. Its not that hard to do, but its very time consuming. Ive replaced heater cores in two 86 4Runners, so i know whats involved.
the1998sr5
15
Jul 14, 2020 08:35 PM
coryc85
Sep 9, 2015 06:24 AM
94 Newbie
Aug 6, 2015 10:33 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
voiddweller
Jul 15, 2015 03:56 PM
