Intermittent start problem
Old Jun 27, 2011 | 10:53 AM
hardieca's Avatar
1988 TOYOTA 4WD TRUCK 22RE/5SPD.
Recently has developed a problem. Intermittently will not start. Can here relay on pass inner fender click, but no start. If you hold the key in the start position it will eventually start(after 20-30 seconds). Sometimes it fires fine. Seems if you let it sit it will not start, once it has started if you turn it off/on as many times as you want, it will start normal. Then let it sit and same 20-30 second delay.
Things I have checked:
-bench tested starter, seems to operate normal.
-replaced starter relay with another(used but operational part).
-metered wires leading to relay to insure getting 12vdc.
I have no idea where to go from here. Everything seems fine, and I don't want to throw parts at it. I have always despised intermittent electrical problems. If anyone has any ideas of what to do, or what to check lease let me know. It's driving me nuts.
Old Jun 27, 2011 | 10:59 AM
xxxtreme22r's Avatar
typical of the starter solenoid contacts starting to wear out. It will eventually not start.
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old Jun 27, 2011 | 11:31 AM
hardieca's Avatar
Thanks for the info and super fast response. I like the water pipe trick. guess this is my next step.
Old Jun 27, 2011 | 02:38 PM
Junkers88's Avatar
Can also be the ignition switch. Had the same problem on mine and replaced the ignition switch and it worked great for a few days. Finally installed the Summit Hot Shot kit and it solved the problem. (that was after doing the starter, checking all the grounds, etc....)
Old Jun 27, 2011 | 07:16 PM
cody o's Avatar
sounds like the solenoid contacts. these darn yotas last so long it becomes an issue. had to replace them on three of my vehicles.
Old Jun 27, 2011 | 07:21 PM
lol that's almost signature material.
Old Jun 27, 2011 | 08:22 PM
toyotacharles's Avatar
agree with starter contacts, about 25-35 bucks in parts and a couple of hours and a skinned knuckle or few and you be good to go
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
