94 3vze ext cab NO BRAKES
Old Jun 25, 2011 | 06:17 PM
bone collector's Avatar
ok guys ive searched and ive tried everything. i have a 94 v6 4x4 ext cab. ive changed the master cylinder, power booster, calipers, rotors, front pads, rear pads are still good and adjusted to the point where i have to use a hammer to slide drum back on. ive bled everything 6 ways from sunday and so many times i lost count. i have absolutely zero pedal. the truck will stop once the pedal is to the floor then it is full brakes. help me out im lost on this one. Thanks
Old Jun 25, 2011 | 06:24 PM
waskillywabbit's Avatar
Bench bleed the MC.
Bled the LSPV?
Bled in the correct order?
:wabbit2:
Old Jun 25, 2011 | 06:42 PM
INFINITY's Avatar
i vote micro bubbles out of the lspv. been there before.
Old Jun 25, 2011 | 07:00 PM
i bench bled the mc i bled the lspv. truck was sittin for 6 monhs before i got it. whats correct order??
Old Jun 26, 2011 | 05:06 AM
can i bypass the lspv?? just use a t- block like whats on the master cylinder??? how important is the lspv?? this is really frustrating. i have gravity bled the lspv for 45 mins then power bled it along with everything else. and still no pedal. there are no leaks anywhere. im really lost on this one
Old Jun 26, 2011 | 08:33 AM
skypilot's Avatar
No; there is a funny loop-back to the lsvp. it takes effort and parts to bypass it.
I bet the MC is defective; its simple hydraulics, force in ,force out at the wheels. If the pedal goes to the floor all that "volume" had to go somewhere??? So it must be bleeding around the piston seals of the MC.
One thought; could your flex lines to the wheels be ballooning?
Old Jun 26, 2011 | 12:39 PM
i changed the MC, and bench bled it correctly. i will check the flex lines. any other ideas??
Old Jun 26, 2011 | 01:17 PM
skypilot's Avatar
I have a 1990 Chevy Scottsdale with an "Isolation Dump" valve that is notorious for sending the brake pedal to the floor, part of the RWAL. Do you have ABS? or some type of RWAL installed? That might be dumping the fluid back thinking the wheels are locked up.
If the fluid is not being lost, all that energy has to go somewhere.
Old Jun 26, 2011 | 03:08 PM
i dont believe it is rear abs, but how can i be sure?? what is the correct bleding order?? i went rear driver rear pass, front pass, front driver lspv. correct ??? nothing has helped any ideas??
Old Jun 27, 2011 | 12:57 AM
TNRabbit's Avatar
That's correct order.
Either you have air or fluid is dumping somewhere. What brand MC? The standard parts store stuff is notorious for 1 in 3 being bad....
Old Jun 27, 2011 | 03:48 AM
the mc is an autozone special. i will pull it off and bench bled it again. and then bled the entire system again. if that doesnt work i will get another mc. thanks for ur help
Old Jun 27, 2011 | 08:26 AM
rattlewagon's Avatar
You can get rid of the LVSP and replace it with a manual valve. I think summit sells them for about 30 bucks.
Old Jun 27, 2011 | 10:00 AM
TNRabbit's Avatar
you should get an Aisin from MarlinCrawler or WabFab
Old Jun 27, 2011 | 05:03 PM
oldblue's Avatar
make sure the calipers are on the correct side of the vehicle. the bleeder screw needs to be at the top of the caliper, if not you won't get the air out. I've seen plenty of backyard mechanics loose their mind over this.
Old Jun 27, 2011 | 05:49 PM
Omg....thats it. i feel like such a noob. i didnt catch it when i changed the passenger side caliper. both bleeders are at the bottom. Doh! thanks for the help. i will change that asap. i feel like an idiot now
Old Jun 27, 2011 | 06:11 PM
oldblue's Avatar
haha, like i said, it's not the first time i've seen this!
Old Jun 28, 2011 | 02:23 AM
Teach me in the ways of the Yota master.....obviously im still a rookie. i cant belive i missed that with how many times i bled the brakes. now i need to go thru this entire new to me truck and see what other stupid things i can find.
Old Jun 28, 2011 | 09:39 AM
TNRabbit's Avatar
Wow; I learned something today. I didn't even know it was POSSIBLE to do that!! LOL
Old Jun 28, 2011 | 11:01 AM
Ya me either. in my defense i bought the truck 3 weeks ago with no brake pedal. whoever worked on the brakes put the calipers on the wrong side. they are exactly the same except the bleeders. once i swapped the calipers to the correct side it has great brakes now. thanks guys especially old blue. i still feel dumb for missing that little detail. of course thats where the devil is....
Old Jun 28, 2011 | 11:25 AM
lozanojalpa's Avatar
Ditto
I ran into this prob. I had to pay a $300 embarassment. SOB i was so mad.
coleypull15
Nov 3, 2015 07:41 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
smiley52
Jul 11, 2015 05:16 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
