89 4runner harness for 86 4runner
Old Nov 3, 2008 | 08:29 AM
slayyerr's Avatar
will an 89 4 runner harness fit an 86-87 4 runner? i found out that my relays and some wires are no good and found someone parting out an 89 4runner.
Old Nov 3, 2008 | 03:28 PM
mnmontana's Avatar
I dont think it would be a dead on fit, but should be 'close'... I'll bet you will still need to swap a few connectors here and there.
I just remade my harness, connector by connector, and it came out really nice. I would recommend that route.
I found a company that sells connectors that are dead nuts on perfect fits for the sensors in my 86. only connectors I had trouble with was the water thermo sensor (had to cut a notch) and the TPS connector, everything else either in good condition or replaced with bone yard connectors...
When your inside the harness, theres 3 sets of factory crimps (guaranteed to be a rusty mess inside any used harness)... I HIGHLY recommend you re-splice, solder them, heatshrink, tape them, and lastly zip tie.
Old Nov 3, 2008 | 03:30 PM
mnmontana's Avatar
btw, it took me about 3 maybe 4 hours total of actual work, done over 3 days to remake the harness... its not nearly as bad as it looks.... Prices I saw for a USED harness was upwards of 300 bucks, and in the same or worse condition than the harness i had.
seriusly.... try to fix what ya got first. Unless of course your gonna drop 500 to 600 bucks on a brand new harness... then go for it.
Old Nov 3, 2008 | 04:38 PM
cuatroxcuatro's Avatar
I tried mating an 85 engine harness to an 87 body/cab harness, even though the plugs fit there were many wires that appeared to be identical but were doing completely different things. It was a big waste of time and effort. Not the same years you are talking about but definitely something to keep in mind.
Old Nov 4, 2008 | 05:06 PM
slayyerr's Avatar
thank you for your replies and input guys (and gals if any out there) i finally found someone that is going to rewire my yota. all i need is the injectors, starter, and alternator. rest i can put switches in.
Old Nov 4, 2008 | 05:11 PM
abecedarian's Avatar
stricly speaking, no... an 89 harness will not work.
liberally speaking, anyone willing to do some re-wiring can make it work.
There are differences between the 86-87 (88 even) and the 89. Some sensors have different part numbers / operating parameters, ignitors are different, ECU is different... list goes on. O2 sensors, injectors may be different... ad infinitum.
MO transplant
Apr 23, 2023 11:58 AM
icentropy
Sep 16, 2020 02:47 PM
Regency
20
Jan 3, 2020 07:43 PM
shar
Jul 9, 2015 12:38 PM
Kluch8651
Jul 9, 2015 10:39 AM
