22RE Exhaust Leak need help ASAP
Old Dec 18, 2011 | 01:18 PM
Jkelley429's Avatar
my truck has had an exhaust leak for about a week. I went to the local parts store and got what they told me was the donut gasket. I got home and looked at the spare manifold i had lying around and cant for the life of me find out where this gasket goes. I looked at my truck and reached up beside the manifold and felt air blowing out the drivers side of where the manifold bolts to the y-pipe. Im assuming i got the wrong gasket as it appears that the manifold takes a regular flat gasket. Does anyone know what the technical name for this part is, or better yet the part number? I was planning on doing this today, but it appears that that probably wont be happening.
Old Dec 18, 2011 | 01:25 PM
toyota4x4907's Avatar
Depends where the leak is coming from. Theres a gasket that goes between the head and manifold (header gasket, exhaust manifold gasket) then there are TWO that go between the manifold and downpipe (downpipe donut gasket) then theres one on either side of the cat converter. The two that go between the mani and down pipe are NOT the same size as the converter gaskets.
Old Dec 18, 2011 | 01:39 PM
Jkelley429's Avatar
im guessing the 2 gaskets are round? would they fit in the 2 holes in the bottom of the manifold? do you know a part number for these? thanks for the help.
Old Dec 18, 2011 | 01:41 PM
Sorry, dont know part numbers.
On the bottom of the mani, should be the exhaust holes and a slightly larger impression around the actual holes for the gaskets.
Old Dec 18, 2011 | 02:00 PM
Jkelley429's Avatar
thanks, ill get those parts tommorow. are they possibly called the front and rear gaskets?
Old Dec 18, 2011 | 02:07 PM
swampfox's Avatar
If you can take an old exhaust donut it is easier to get the right ones. The part store has trouble looking up the right ones for some reason.
Old Dec 18, 2011 | 02:11 PM
Jkelley429's Avatar
ok, ill try that. i dont get off school til 3 and i need it to get there so hopefully i can get it done. about how long do yall think it will take?
Old Dec 18, 2011 | 02:19 PM
Give yourself a few hours. The most difficult part is going to be breaking the bolts loose. They WILL be rusted and MOST LIKELY will strip. It would be a good idea to replace the studs and nuts at this time. Very good idea to...
Old Dec 18, 2011 | 03:06 PM
rworegon's Avatar
Hit the change vehicle, put in your rigs info, and look up any part number you may need.
http://www.toyotapartseast.com/secti...uel-11946.html
Exhaust is under the Tool/Engine/Fuel tab.
Old Dec 18, 2011 | 03:17 PM
Jkelley429's Avatar
thanks, i think i got the right number.
Old Dec 18, 2011 | 03:24 PM
rworegon's Avatar
Welcome....it's a real handy website.
Old Dec 18, 2011 | 03:25 PM
Jkelley429's Avatar
yeah, it definitely will!
tj884Rdlx
Aug 28, 2015 12:04 PM
the1998sr5
Jul 16, 2015 06:20 AM
hexrain
Jul 12, 2015 01:13 PM
Coreyr384
Jul 10, 2015 11:13 AM
Avenged
Jul 9, 2015 07:55 AM
