1990 bench seat replacement
Old Dec 16, 2011 | 04:51 PM
silvr6's Avatar
Just started fixing up the old ranch truck. The interior is starting to shows its age. The bench seat in my 1990 Toyota pickup is in pretty bad shape and seat covers are not going to cut it any more. I have been looking for a replacement bench or something similar. I have found a grey 60/40 bench out of a 1998 extended cab.
Will this seat work with my 1990 standard cab pickup?
Old Dec 16, 2011 | 06:34 PM
93YotaGuy's Avatar
Sure it will! With some fabrication/modification. It's unlikely that it will be plug and play.
Good luck!
Old Dec 16, 2011 | 08:09 PM
xXbrutalXcoreXx's Avatar
Seeing as how the seat is coming out of a Tacoma, I would definitely say some modification would be required.
Old Dec 17, 2011 | 05:20 PM
silvr6's Avatar
Well my only other option would be to recover the original bench. Dose anyone make a original seat cover. I have replace the covers on my Early Bronco so a bench should be easier.
Old Dec 17, 2011 | 05:26 PM
Teuf's Avatar
Get the 60/40 and make it fit. You can do this............
Old Dec 18, 2011 | 01:35 PM
mountaingoat92's Avatar
IMO, Yota seats just out right blow and its likely unless you get a worn out seat from the correct generation that you are going to be doing some fabin anyway. I've got the middle seat from a mid 90's dodge caravan and it is SOOOOOO much better than the stock Yota bench. Fits in my 92 reg cab just fine. Just built some metal brackets. Of course if you can't weld you'll have to make a weldor friend.
Old Dec 18, 2011 | 05:44 PM
silvr6's Avatar
The deal for the 60/40 seat may be gone.
Is there anyone that makes a replacement seat cover?
Not looking for a seat cover over the torn original fabric!
Old Dec 18, 2011 | 08:56 PM
ThurzNite's Avatar
This's a stretch, but there's a handful of maybe ok ones here http://car-part.com. I'd ask for pictures at least.
Otherwise, I heard a friend went to Mexico and got a rebuilt one that's like-new. It looked great and cushions weren't sagging either.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Johntom240
7
Jul 13, 2015 12:18 AM
A2theK
Jul 12, 2015 10:46 AM
icentropy
Jul 9, 2015 02:12 PM
ptb12
Jul 5, 2015 01:49 PM
