89 yota
Old Sep 4, 2012 | 06:13 AM
DSMITTY's Avatar
89 yota
I have a 89 yota 4x4 started the other day half mile going down the road it is lagging not sputtering or nothing just lagging. Changed fuel filter but the truck starts and runs fine no problem what could it be. Check engine light is on
Old Sep 4, 2012 | 06:51 AM
racerflea's Avatar
Is ur ignition coil plugged on it good?? I put a msd on nine but didnt put it all the way on and it felt like the was trying to die
Old Sep 4, 2012 | 08:05 AM
DSMITTY's Avatar
yota
Yea its on good could it be the mass air flow sensor or would that be a possibility
Old Sep 4, 2012 | 08:51 AM
racerflea's Avatar
Did u do anything to this truck before this started or did it come from nowhere mid run
Old Sep 4, 2012 | 08:52 AM
racerflea's Avatar
Not sure what u mean by "lagging"
Old Sep 4, 2012 | 09:00 AM
TNRabbit's Avatar
I'm not a rocket scientist or anything, but if you have a check engine light.... wouldn't it make sense to pull the codes??
Also, for the record....your engine dkesn't have a MAF; it's a VAFM (vane air flow meter). They work completely differently.
Old Sep 4, 2012 | 09:05 AM
DSMITTY's Avatar
yota
Yea i can pull the codes juat curious is to see if any of yall had a problem like this and could go right to it. You put the throttle down while in gear feels like you are running half power.
Old Sep 4, 2012 | 09:16 AM
TNRabbit's Avatar
That could be a dozen different things. Pull codes & get back to us....then maybe we can point you in a specific direction.
Old Sep 4, 2012 | 09:21 AM
waskillywabbit's Avatar
Pull the codes.
:wabbit2:
JonG85
Jan 18, 2023 04:31 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Ditch Doc
Oct 27, 2015 03:20 PM
shredder4286
Oct 1, 2015 01:09 PM
