Need help truck sputtering
Old Aug 30, 2012 | 06:09 PM
Meche yota's Avatar
Hi guys, I'm new here. I have a 1991 yota reg can 5 speed base model. My problem Is whe I crank it and take off down the road after about a mile or two it will lose power until it warms up. It's like sputters won't go unless I let off the gas. When it warms up it runs great not a glitch. Only does it when it's cold. I have replaced plugs,wires,rotor,cap,coil,pickup coil, tested fuel pressure it's at 35 psi. I have sprayed all vaccum lines with carb cleaner and didn't change anything. I'm now leaning towards o2 sensor and coolant temp sensors. Any help would be great appreciated!
Old Aug 31, 2012 | 10:29 AM
Meche yota's Avatar
Anybody?
Old Aug 31, 2012 | 10:56 AM
westjohns yota's Avatar
possibly a clogged cat? check your fuel pressure regulator hot and cold? fuel pump could be loseing power before it warms up, just a list of things, you said fuel pressure at 35 so i assume its a 22re? fuel injected
Old Aug 31, 2012 | 10:57 AM
waskillywabbit's Avatar
CSI perhaps
:wabbit2:
Old Aug 31, 2012 | 11:04 AM
Meche yota's Avatar
Yes it's a 22re. This morning I sat under the porch and let my truck warm up. No problem after warm up. I'm in Louisiana so the cold weather is really not a factor here.
Old Aug 31, 2012 | 06:15 PM
Meche yota's Avatar
Incan now gear it backfiring though the intake maybe. I need some help guys.
Old Sep 1, 2012 | 09:36 AM
Meche yota's Avatar
I pulled the o2 sensor off and Tryd to read the voltage with my meterand a propane torch.. It's doesn't read any voltage. Does it mean thati need a new one?
Old Sep 2, 2012 | 09:19 AM
Meche yota's Avatar
Ok guy I got it fixed. I changed the o2 sensor, coolant temp sensor and thermostat. Runs like a dream. Tks for the help.
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
thelifeadventure
Jul 2, 2015 03:09 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
