Trans/ xfr case compatibility
Old Jan 25, 2019 | 10:34 AM
roughridn_sob's Avatar
Simply:
Will a Forward shift W56-C trans from a 89 pickup bolt up to my topshift W56-B transfer case?
My trans lost 4th gear and now the input bearing is getting loud. Haven't been able to find a top shift trans but managed to find a rebuilt top shift without the xfer case. Is it a simple block off plate fabrication to cap the hole in the trans?
Old Jan 28, 2019 | 05:27 AM
wow nothing? I for sure thought someone would have this answer....
Old Jan 28, 2019 | 07:45 AM
coryc85's Avatar
I don't know 100% for sure, but to me, seems like answer is yes. I'm assuming your tcase shifter hole in the truck will have to be moved or elongated, and if that doesn't bother you, then go for it. I know that there are kits to convert a forward shift to a top shift, which implies then that the forward shift can be used in top shift applications, so I would think bolt wise and input shaft wise, they are identical.
Old Jan 29, 2019 | 04:24 AM
muddpigg's Avatar
My crawler box was forward shift. I trimmed rails to not bump w56b. Been running it for years. So feel confident to say it will work the other way. You will want a block off plate to keep trash out. Can not say if there’s a difference in floor pan opening. But easy enough fix.
Bridger5228
May 24, 2010 08:57 AM
Ilovemountains
Jan 27, 2010 08:30 AM
sandracer33
Sep 12, 2007 06:39 PM
Keggo
Aug 27, 2006 05:54 PM
kccorvette
Feb 7, 2006 07:51 PM
