Could problem be anything but cracked head?
Old Jan 20, 2019 | 05:29 PM
ethanfurniss's Avatar
Hi,
I've searched and troubleshot and can't find out what's wrong with my 1994 4X4 with a 22RE. I am writing this to save some time, money and energy. I thought I'd pick your brains before taking the head off again.
Symptoms: steam out of tailpipe and bog when I hit the throttle after replacing and servicing the following parts. There is no overheating and for the most part, it idles fine.
New Parts and services:
  • OEM head gasket
  • head bolts
  • block head bolt holes tapped and cleaned
  • rebuilt head (was told it was checked for cracks, valves and seats were ground, seals replaced and decked)
  • new RV cam
  • new water pump
  • new timing chain and guides
  • new injectors
  • new spark plugs
  • new clutch kit
  • new coolant temp sender (the one below the throttle body)
  • cleaned throttle body
  • cleaned upper and lower plenum
  • timing set
  • I did not touch the TPI
  • Copper spray used on head gasket
Compression is 170 (+- 3) psi across all cylinders read after work was preformed.
Story:
The truck ran fine until I blew a head gasket. When it went, I saw steam out of the tail pipe and had a loss of power. The temp gauge read normal when it went which is just a little below half way. There was no corrosion visible in the radiator. I made a plan to replace the head gasket, rebuild the head and replace the clutch all at once. I followed the best practices that I am aware of EXCEPT for not having the block decked. It didn't look great. Because I just started an electrical apprenticeship and I'm working 60 hours per week (time and money) I decided to skip the rebuilding of the bottom end. I don't think this has caused my problem. My assumption is that the block will be fine for a couple of years. By that time I'll be making more money and buy a long block or replace the vehicle.
Question:
  1. What, other than a compromised head gasket, could be letting coolant into the combustion chamber?
  2. Could the head be cracked? The shop said they checked it but then again, they are only humans.
  3. Could coolant be leaking into the plenum through the throttle body? I bypassed the TB coolant lines and saw no different results.
  4. Could the block be cracked? Since I saw ≈170 psi from all cylinders after the work I don't see how this could be the problem.
  5. What should my next steps be?
Thanks for your opinions and suggestions. Yotatech, Pirate4X4 (and Thumpertalk) have been great mechanical resources for me over the years.
-Ethan
Link to photos https://photos.app.goo.gl/cCdSi3bab5utTPqL7
Old Jan 20, 2019 | 07:22 PM
Blownchevelle68's Avatar
I just finished a head gasket and other items this week. I was told that surfacing the head and block is very important in getting a good seal- as Well as a factory head gasket
Old Jan 20, 2019 | 08:23 PM
Thanks BlownChevelle68. If I didn't get a good seal then why are the compression readings so good?
Old Jan 21, 2019 | 12:37 AM
ev13wt's Avatar
5 Year Member
Is the white smoke there after it warms up? It's not water in the tailpipe?
The bogging is what is weird to me. Recheck timing chain position and distributor position.
Old Jan 21, 2019 | 03:50 AM
Co_94_PU's Avatar
Perform a cylinder leakdown test. This gives you a better overall sense of each cylinders seal. You can have excellent compression and still have a leaking head gasket.
Are you loosing coolant, seeing as it's winter in North America some steam is to be expected.
​​​​​​suck squirt, squish bang, blow.. Repeat.
Double check your work, then do it again!
Are all the ground wires clean and connected?
Lines and wires routed correctly and tight/clean?
Is the initial timing set to the right ballpark?
Old Jan 21, 2019 | 05:25 AM
snippits's Avatar
Could be a lower intake leak.
Old Jan 21, 2019 | 05:33 AM
87-4runner's Avatar
It will take some driving to get the moisture out of the entire system... i just did a head gasket replacement myself and mine smoked for a while till after my second oil change... the first one looked like coffee with creamer in it... but it cleared up and the oil is clear...
did you set your valves?
Old Jan 21, 2019 | 05:41 AM
^^Spot on.^^ I've had them show great static #'s but a leak down would show slow bypass. And i've had different readings on a cold engine VS. one that is close to operating temp. But as mentioned, double check everything before thinking the worst.
I did not have my block decked, but the head was surfaced. Also the intake mating surfaces all need to be cleaned well. I went over mine with a 8" sanding block and 80 grit followed by 120 grit paper until all low spots were taken.
I didn't use any copper or other sealing goo on the gasket or deck surface. Only cleaned several times with brake clean and blew out everything well.
Old Jan 21, 2019 | 05:10 PM
Hey man,
the white smoke is constant. It's steam I'm sure. There isn't a ton until I try to rev the engine. There was water in the tailpipe but the engine has run now for a total of ≈40 minutes. Any water in there has been cleared out imho.
The timing is spot on and the distributor is in the same location that it was before I removed it. I think that rules out chain/distributor position.
Old Jan 21, 2019 | 05:35 PM
A cylinder leak down test is a good idea. I've never done one but I'm sure I can source the tool easily.
I have not noticed the coolant level drop at all. There is just a little bit of steam at idle and that's what the engine has done most. I haven't driven it.
I love the suck squirt bang blow saying.
The engine compartment is clean and the ground locations looked the same.
To my knowledge all wires and lines are clean, correctly located and functioning.
The timing is set per factory service manual.
Old Jan 21, 2019 | 05:36 PM
That was my first idea. I have replaced that gasket for the second time to no avail.
Old Jan 21, 2019 | 05:38 PM
I usually change the oil after 20 miles after major service. Since the oil is clear and there is no moisture under the filler cap I don't have a reason to believe there is still moisture in the lower part of the engine.
The valves have been set per factory service manual specifications.
Old Jan 21, 2019 | 05:47 PM
Hey man, thanks for the input. The engine was close to operating temp when I performed the compression test. Maybe I should perform one cold for comparison.
Things I have not double checked:
  • head torque- I did this 3 or 4 times before putting the valve cover on though
  • Valves- when I got the head back from the machine shop they were really loose. I assume they loosened them for disassemble or when installing the new cam. Before starting the engine for the first time I set the valves to spec per factory service manual instructions. I was going to set them again when I re-torque the head bolts.
  • injectors with old injectors
  • cold temp sender- I broke the old one and replaced it with a non-name brand off the internet. *no codes are present on the dash
Old Jan 21, 2019 | 06:04 PM
Co_94_PU's Avatar
If the intake runner surface isn't to spec you can change that gasket as much as you want and it still very apt to leak... The spec is 0.2mm.. An "insignificant" scratch..
There is also the long bolt that goes into the water jacket which needs sealed.
There are also a few vacuum and water lines that could get mixed up, yes generally this means lots of water in the combustion but not always enough to hydrolock.
Find and fix the leak first, worry about the performance issue second.
Old Jan 21, 2019 | 09:32 PM
There is also the long bolt that goes into the water jacket which needs to be sealed.
Scratch on intake runner: You think I might have a scratch on the surface between the head and intake? That doesn't sound impossible but it does sound improbable. No offense. My assumption would be that a ≈3mm thick gasket with silicone (I think) printed on it would bare any scratches from removing gaskets insignificant. Then again, I'm stumped and your advice is sound. I'll look for scratches there if I end up doing the work and bring it up if I have a mechanic do the work. I'm going to be transparent though, I want to do as little work as possible. I know that's not best practice and that statement will make me sound lazy. This job has taken quite a few weekends as it is and since I only have one day off and work 60 hour weeks I'm eager to get it back on the road. Last Saturday night it took me 5 hours (one per beer) to get the runner off enough to scrape the one-week-old gasket off and replace it. To do a good job at cleaning the surfaces it would likely take me more hours than that.
Long bolt: Is the long bolt you are referring to the ≈60mm hex head that is one of ≈6 bolts and nuts that hold the lower manifold on? That would take fairly little time to seal if by seal you mean add rtv to the threads and hole in head. However, I don't see anything in the FSM about this.
Find and fix leak comment: My assumption is that the leak is causing the performance issue.
Thank you for your comments.
What can I learn or rule out from a leak down test?
Old Jan 21, 2019 | 09:54 PM
Co_94_PU's Avatar
​​​​​I am not saying this is the problem only that it might be..
The long bolt I am referring to goes in the second spot back along the top of the lower intake to head interface.
Old Jan 22, 2019 | 05:05 AM
snippits's Avatar
Get a Block Tester, and verify combustion yes or no in the coolant. You can rent one at O'Reilly or AutoZone. You will probably have to buy the test fluid. Either way just make sure you have the test fluid.
https://www.oreillyauto.com/detail/b.../67094/4700290
https://www.oreillyauto.com/detail/b.../75630/4414187
https://www.autozone.com/loan-a-tool...r-block-tester
Old Jan 22, 2019 | 09:46 AM
akwheeler's Avatar
For me the bottom line comes down to "are you loosing coolant"? If I suspect a head gasket leak I perform a cooling system pressure test and see if I am loosing pressure over time and how fast the pressure drops.
Then I start looking for where the coolant went. Pull the spark plugs and roll the engine over by hand and see if coolant comes out of one or more cylinders.
If it holds pressure and you don't seem to be loosing coolant keep in mind that antifreeze doesn't evaporate like water and after your first head gasket blew there would be coolant in the exhaust that will take quite a while to burn off.
Old Jan 22, 2019 | 11:14 AM
Thank you. I'll cross reference that suggestion with the factory service manual. How do you suggest sealing that bolt? RTV in the threads?
Old Jan 22, 2019 | 11:17 AM
That's another tool that I'm unfamiliar with but I'll try and make the time to check it out.
What does "combustion yes or no in the coolant" mean and what else can I learn from a block tester?
