2wd capacity diff
Old Feb 10, 2019 | 12:34 PM
Cesar Telles's Avatar
2wd capacity diff
hey guys, I’m filling my rear diff fluid on the full plug and it started to pour out at about 1.5 quarts, so I’m wondering how much is the capacity on it ? It’s a 94 Toyota pickup 2wd 7.5 rear
Old Feb 10, 2019 | 01:11 PM
Also when I took off the fill plug, gear oil gushed out as if it was the drain plug, so I’m wondering if there’s another way to get the fluid in the from the top ?
Old Feb 11, 2019 | 12:35 AM
75w90mantraN's Avatar
Only through the fill hole. A hand pump connected to the bottle of fresh oil is one method. Plastic tubing and gravity is another.
Fluif expands after a drive. Even so, its normal for some to seep out when its cold. Assuming you are parked on a level surface.
Dont have the specs but you should have no problem looking that one up. Its less than typical oil changes so be careful not to overfill.
Old Feb 12, 2019 | 08:00 AM
dropzone's Avatar
Fossilized
usually about 2 quarts but you are using the correct fill method.
Drain from bottom plug
fill from plug on rear of housing until is comes out.
you remove the vent on the top and fill from the top
Old Feb 12, 2019 | 08:11 AM
beef tits's Avatar
Check that your vent isn't clogged - I pull mine out and clean them every time I change fluid.
Otherwise, 2 - 2.5 qts sounds about right. They don't take much.
Old Feb 12, 2019 | 09:06 AM
snippits's Avatar
3 pints or 1.5 quarts is correct for the 2wd 7.5.
https://www.amsoil.com/lookup/auto-a...e-l/us-volume/
sonyasofia
May 5, 2018 04:23 PM
Odin
Sep 26, 2015 06:56 PM
PedroMartinez
Dec 7, 2012 03:45 PM
igotit
Sep 17, 2011 02:19 AM
RJR66
Oct 25, 2009 05:34 PM
