86 4Runner - Finding stock spare solution
Old Feb 20, 2019 | 12:40 PM
frikinyankee's Avatar
Hey all,
So i recently got an 86 22re 4runner automatic
I have the stock jack and tire tools
But no spare underneath. I'm about to get new tires, so I thought I'd also get a spare rim and put one of the old tires on there for emergencies
Well... attached a pic of my underside. It seems like it's missing the part that should be on the end of the chain that holds the rim in place.
1) Should I just replace the whole assembly? Feels like it just bolts on there. Will a newer one bolt on? I'm seeing a bunch avail on ebay from 96 on. None from 1st gen. The concern with this is then the tool I have won't work, or will it? These newer ones just work with what looks like a 1/2" socket end, is that right?
2) What rim? I'm not too familiar with truck rims in general. From what I've gathered I've got the 15" high x 6" wide and 6studs 5.5 inches apart center to center, is that right? What about clearing the brakes, and depth of the wheel part. Will most 15" toyota wheels fit? Looking for a cheap online solution to this and it doesn't seem that easy to find these rims... am i looking in the wrong places?
Old Feb 20, 2019 | 01:34 PM
mholme's Avatar
In theory, it’s a bolt on swap. It’s going to fight you. I think I snapped all three bolts replacing mine. A new carrier is 100 dollars or so from Toyota. I run 31” 10.5”x15” tires including the spare.
You should be able to find spare wheels from a yard or remanufactured from rockauto.
Old Feb 20, 2019 | 02:13 PM
wallytoo's Avatar
i got lucky with mine, and was able to remove the three bolts, which i replaced with new. believe it or not, i used the supports for my kids' training wheels as a substitute for the wheel anchor at the end of the chain; free, and it has worked for six years now. i've got a thread on t4r.org that shows my refurb of the lifting mechanism.
Old Feb 20, 2019 | 04:57 PM
I can't find the stock spare carrier part number for the life of me! Any leads?
Interesting! Got a link by any chance?
Old Feb 20, 2019 | 05:07 PM
RAD4Runner's Avatar
O.P. You're talking about the long extension to the jack handle with a hook / loop on one end? Don't you have that anymore?
.... I run 31” 10.5”x15” tires including the spare.
..., i used the supports for my kids' training wheels as a substitute for the wheel anchor at the end of the chain; free, and it has worked for six years now.
Yes^^^
Yeah, pretty easy to find or fabricate out of a strip of steel. Junkyards are your best bet if you don't want to spend much.
I also removed mine, soaked in PB blaster, cleaned greased and re-installed.
I have a 31" on stock 15-inch steel rim, too. It gets very close to the exhaust pipe,so I use a cam-lock strap to pull it away from the exhaust pipe. I also bought the insulating wrap for exhaust pipe but I spend more time on adventures than working on truck - LOL!
BEFORE
CAM-LOCK FOR BIAS
AFTER
Old Feb 20, 2019 | 05:25 PM
mholme's Avatar
Toyota lists two part numbers, 1 specifically for alloy wheels. That one is discontinued. The other part number is 51900-35121
There is one on eBay right now, don’t know which one it is or why there is one specifically for alloy wheels. I would think as long as the bolt pattern is for a 6 bolt 4WD that either one would work.
http://vi.raptor.ebaydesc.com/ws/eBa...05524000&ver=0
Here is the link to wallytoo’s thread https://www.toyota-4runner.org/class...-thread-3.html
Old Feb 20, 2019 | 11:40 PM
SomedayJ's Avatar
Do you have a pic of the one for alloy whees?
Old Feb 21, 2019 | 06:37 AM
scope103's Avatar
This online dealer https://parts.lakelandtoyota.com/sho...rimLevel=18419
Seems to give 51900-35160 ($120)
as the part number for alloy wheels for this model (RN6#)
The drawing and list of part numbers might help.
(Sometimes discontinued parts can still show up on this website. A phone call would be worth your time.)
Old Feb 21, 2019 | 03:38 PM
wallytoo's Avatar
starts here and continues in several more posts in my thread.
Old Feb 22, 2019 | 03:17 AM
snippits's Avatar
http://www.car-part.com/
Use your VIN number. You will be hooked in to automotive recyclers all across the country.
Old Feb 22, 2019 | 10:11 PM
Very cool thanks!
Looks very doable to rebuild, maybe even change the chain? The only part that I'm missing from those pics is how the 'anchor' (is that what it's called?) hooks onto the chain.
I'll restore the winch I have, but I'd like to make sure whatever I rig as an anchor works VERY well. I mean... you don't wanna drop a spare tire on the highway, right? Got any closeup pictures of how the anchor part is constructed and hooked onto the chain? be curious to see how if i can manufacture it
wrenchtech
Sep 28, 2017 09:12 AM
clos88runner
Oct 23, 2007 07:28 PM
4cloud9
Apr 9, 2006 09:33 AM
lee
Aug 9, 2005 05:55 AM
fs8459
Feb 13, 2005 05:59 PM
