Blower control replace
Old Jan 10, 2019 | 08:26 PM
JJ'89's Avatar
'89 2wd 22RE. The only speed that works is highest blower. The lower speeds gave up one at a time over a period of years.I see the controller which I suppose switches various resistances listed on rockauto. How much of a job is this to replace? I'm in WA and my pubs for the pickup are in CA. Thanks Jim
Old Jan 10, 2019 | 08:51 PM
dropzone's Avatar
Fossilized
Your symptoms sound the same as mine.
root cause for mine was the blower motor resistor. On passenger side inside firewall behind the glovebox
that in turn caused the switch to fail. Basically had to start on the right side and pull the dash apart working towards the center. Somewhere towards the beginning of my build thread I have pics
edit
post #245
https://www.yotatech.com/forums/f199...l#post52330928
Old Jan 10, 2019 | 11:10 PM
RAD4Runner's Avatar
Originally Posted by JJ'89
'89 2wd 22RE...
Most likely cause of your issue is the resistor like Dropzone'and mine. After many years the coils.burn out.
​If 4Runner, I remember mine to.be a simple, easy job.​​​​​​
Don't quite remember if I posted about it.
Resistor module is somewhere behind the glove compartment, IIRC.
Old Jan 11, 2019 | 03:19 PM
JJ'89's Avatar
Many thanks; I'm hoping a new resistor assembly from rockauto will do the job...order it sent to bro's house for next trip down. Thanks again
Old Jan 12, 2019 | 04:05 PM
JJ'89's Avatar
DuckDuckGo was my friend....
Old Jan 12, 2019 | 09:18 PM
old87yota's Avatar
Yes^^!
A classic Eric O. from South Main Auto Repair video.
I watch his channel all the time.
adk4runner
Aug 4, 2019 07:12 AM
cpljenkins01
Sep 24, 2018 06:19 AM
HappyMostly
Jul 14, 2010 05:26 PM
4rnr
Oct 2, 2007 03:36 PM
JSharp
Oct 9, 2004 11:36 AM
