Idle issue
Old Jan 9, 2007 | 07:22 PM
Sonofmayhem's Avatar
Idle issue
Ok, my truck will only stay alive with the idle adjusted real high, i dont have a tach so i cant get an exact number. but if we lower it it bogs down and dies. the timing is on, new plugs, compression was 130 all the way across, now could it be the EGR valve? we found some akward wires, does anyone have a wiring diagram or a link to one? thanks
I searched but didnt find anything relevant.
Old Jan 10, 2007 | 02:53 AM
Yotapup's Avatar
Just a thought. Did you check the TPS? Vacuum leaks? Here is a link to a FSM.
http://personal.utulsa.edu/~nathan-b...fsm/index.html
Old Jan 10, 2007 | 05:49 AM
nope. but how do i do that? i also did use the FSM thanks.
Old Jan 10, 2007 | 05:50 AM
automated11's Avatar
If this is on your truck my 1980 yota pickup did the same thing. All i needed was a new PCV valve and gasket. All fixed
Old Jan 10, 2007 | 05:58 AM
Na, i sold that one, but i may replace it anyways. its on my 89 4runner 22re, 5spd.
Old Jan 10, 2007 | 06:26 AM
Yotapup's Avatar
The FSM has a section that shows you how to adjust. Go To:
Engine
Throttle Body
Tps will be at end of section.
Not saying that is problem but it is a simple check .
The FSM has a good troubleshooting section also.
Old Jan 10, 2007 | 07:47 AM
rdlsz24's Avatar
What do you mean awkward wires? I just finished up a top end refresh on my 22RE, so I have a pretty good picture of what goes where in my head right now.
Rob
Old Jan 10, 2007 | 08:21 AM
MMA_Alex's Avatar
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Jan 10, 2007 | 10:21 AM
Someone cut off the plug to some wires on top of the engine so we dont know where to put them. ill find out the colors later, does anyone have a wiring diagram or a link to one? thanks
Old Jan 10, 2007 | 10:39 AM
rdlsz24's Avatar
Check out Figure 23 on this page. Also, if you tell me the colors, I could let you know what they go to since I'm going to be working on my truck tonight.
Rob
Old Jan 10, 2007 | 05:12 PM
red/black stripe
blue/white stripe
yellow/black stripe
They are all single wires and
They are in the same strand of wires as the emmisions
Old Jan 11, 2007 | 05:38 PM
I believe i read that the red/black stripe, deals with the tps, however the tps plug in is un cut. here is a pic of the cut wires.
What does this sensor do? i think the yellow/blackstripe went to it...
Old Jan 12, 2007 | 09:37 AM
anyone?
Old Jan 12, 2007 | 04:57 PM
timebandit's Avatar
130LBS sounds a little low. Should be ~175 on the 22R. Compession ratio is
10.?:1.
Old Jan 13, 2007 | 09:14 AM
well the engine was still cold, i am pretty sure it will jump up soon, it was sitting for a while the piston rings werent sitting right so we used some tranny fluid through the spark plug hole to help and they jumped from 120 to 130 and 90-130.
Old Jan 13, 2007 | 03:19 PM
Old Jan 13, 2007 | 03:47 PM
Targetnut's Avatar
If I can remeber to do so I'll look at a wiring diagram at work on Monday and get with you on those wires. The only diagrams I have available to me right now only go back to '90 and they do not show any wires those colors.
The single yellow/black wire could be to the oil pressure switch and the brown/black wire is likely to be a sensor ground.
Old Jan 13, 2007 | 04:33 PM
I would really appreciate that.
Old Jan 14, 2007 | 03:40 PM
Old Jan 15, 2007 | 04:07 PM
Did you remember?
