Growling front wheels
Old Jan 14, 2007 | 06:58 PM
bike4miles's Avatar
Exclamation Growling front wheels
My front right weel is growling and vibrating on and off but it has gotten super bad and I need to take care of it ASAP. It did this last winter and I re-built the bearings up front and it stoped but I suspect there is a bigger problem here. Arn't there some brass bushings up there that cause this problem? What do I need to do to fix it? What tools, parts, and time do I need to devote to this project? Any pictures and writeups would be appreciated! Thanks!
Old Jan 14, 2007 | 07:04 PM
mastacox's Avatar
My front left wheel was making a wierd noise kinda like a growl, and it needed grease in the hub.
Just throwin' it out there
Old Jan 14, 2007 | 07:24 PM
tc's Avatar
tc
search "spindle bushing"
Lots of questions/threads about it lately...
Old Jan 15, 2007 | 01:21 PM
bike4miles's Avatar
Ok, I did some reading. I'm interested in just greasing it for now but I couldn't fully understand what I would need to do. Could I just pull the wheel and disc rotor and lube up the cv axle by squishing some grease in there or mabe some spray lube? I really don't have a lot of tooks at my desposal right now.
Old Jan 15, 2007 | 03:17 PM
AH64ID's Avatar
grease the spindle bushing and wheel bearings...
look for the part toyotaMDTtech (Sp?) posted up on here a few months back...
Old Jan 16, 2007 | 11:21 AM
bike4miles's Avatar
Can I do this without pulling the ball joint or CV? If so It will be a quick fix and that is what I am shooting for!
Old Jan 16, 2007 | 09:35 PM
AH64ID's Avatar
Shouldnt have to pull a BJ, but the CV might have to come out for the spindle bushing... it doesnt for the wheel bearing.
Old Jan 17, 2007 | 02:05 AM
91 4Runner's Avatar
If you have to go as far as pulling the spindle, you can do it just by unbolting the 4 bolts on both ball joints. You will also have to pull the hub, center bolt and c-clip,the steering rod (that the brake line mounts to) and caliper. You will need to force the upper and lower a-arms apart - stock bottle jack works great for this. I just replaced the spindle on my passanger side and all in all it took me 2 hours with hand tools. So all in all not bad...
Old Jan 24, 2007 | 03:52 PM
bike4miles's Avatar
Well I ended up just pulling the brake rotor/ bearings and then pushine in the CV and smooshing some grease behind there. It seemed to work but if it doesn't last I guess I will have to tear into it more.
Old Jan 24, 2007 | 06:15 PM
PoleVaulter95's Avatar
he is right i had that same problem and i used those instructions to make my own tool and it worked so easily. good luck
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1994toyota
Jul 17, 2015 03:03 AM
skoti89
Jul 6, 2015 07:45 PM
