starter issue?
Old Jan 15, 2007 | 02:30 PM
swerks's Avatar
starter issue?
I have a 86 4Runner Turbo with an automatic. Intermitantly when I go to start my truck the starter just seems to spin very fast like the starter is not engageing any thing. I turn it off and try a second time and it almost always starts imediately. any thoughts??????
Old Jan 15, 2007 | 02:49 PM
rdharper's Avatar
Probably the starter not pulling in... lots of stuff on this if you do a search. Something like: starter solenoid engage
Old Jan 15, 2007 | 03:34 PM
dcg9381's Avatar
I think the term you're looking for is starter "bendix" - it's the thing that throws the starter gear into the flywheel.
It could be the starter gear or flywheel itself also... I don't hear of starter bendix failures on the 22r series, but you might ask around..
Old Jan 20, 2007 | 01:01 PM
swerks's Avatar
why does this happen more when its very cold out???
Old Jan 20, 2007 | 01:17 PM
rdharper's Avatar
If the solenoid is encountering enough resistance to hang periodically, it could well be that "cold" makes the resistance worse.
Picture how it works... you apply power to a solenoid (and the starter motor itself) that pushes the bendix gear out to engage a (ring?) gear that will turn the engine. If anything physically hangs up that movement, or the solenoid is not getting full voltage due to poor contact somewhere, or the starter motor itself has weakened in some fashion, you get the symptoms you describe.
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
mluz013
Aug 2, 2015 05:00 AM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
