R150F Upgrade
Old Jan 28, 2009 | 06:02 PM
T-1000's Avatar
R150F Upgrade
Am I correct to think that this
http://www.marlincrawler.com/transfe...ine-input-gear
makes the R150F have a 23 spline output to the t case like the R151?
Also, does the R151 share a common bellhousing with the R150F?
Old Jan 29, 2009 | 05:33 AM
JackKnife's Avatar
No. The R150F already has a 23 spline output.
The 23 spline input gear goes into the gear drive transfer case to either replace a 21 spline or upgrade an existing 23 spline to Marlins total-spline.
To answer your second question... The R150F bellhousing mounts to a 3VZ-E while the R151F bellhousing mounts to a 22R/RE. So they aren't the same. But the bellhousing can be swapped between these transmissions.
Old Jan 29, 2009 | 05:46 PM
T-1000's Avatar
Thanks. Very good information. Exactly what I needed to know.
kawazx636
Oct 6, 2021 03:03 PM
SpookyMulder
Nov 4, 2015 11:56 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
89YodaRunner
Sep 30, 2015 02:18 PM
4runnerFireman
Sep 29, 2015 06:24 AM
