tachometer install help (pic included)
Old Jan 31, 2009 | 01:08 PM
needsomecam's Avatar
here is a picture under the hood to show you what im workin with:
which wire is my "signal" or "sender" wire for my tachometer so that it functions properly. Thanks mucho.
Old Jan 31, 2009 | 02:42 PM
drew303's Avatar
get another shot from above further out
i can hardly tell what im looking at
Old Jan 31, 2009 | 03:31 PM
iamsuperbleeder's Avatar
it's the coil
but I couldn't help ya there; my 91 just has the cylinder style coil with just a + and - lead, and on that type you install you signal wire to the tach (normaly a green wire) to the - on the coil
but that style looks to have just 2 wires, probably just a + and -, so just probe them and see which ones hot with the ignition on. Whichever one has 12v to it, use the other wire!
Old Jan 31, 2009 | 04:32 PM
abecedarian's Avatar
... uh... the one that has 12v doesn't change- it always has 12v....
Unless I missed something somewhere, the igniter (points for the others) opens and closes the ground, thus providing the trigger for a tach.
Old Jan 31, 2009 | 08:34 PM
okay so see the two wire plug? theres a black wire with a white tracer and a black wire with a red tracer. One of those it keyswitch power and the other one is a sender wire?
Old Feb 1, 2009 | 08:25 AM
bump. read last post please.......need help
Old Feb 1, 2009 | 09:55 AM
not so much a "sender wire", but it's the ground to the coil to complete the circut. that's the wire you want to hook you tach signal wire to
Old Feb 1, 2009 | 10:09 AM
Hayes's Avatar
sender wire should be green... Was in mine anyways.
Old Feb 1, 2009 | 11:51 AM
wire on the tach or coil? the wire on the tach that goes to the coil is normally green...
hey what's the latest on 1972TLC; haven't heard anything new in a while; just curious
Old Feb 1, 2009 | 12:06 PM
Hayes's Avatar
sender from the coil.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
crashburnoveride
Jul 10, 2015 06:39 AM
