R150F vs R154
Old Jan 27, 2009 | 06:44 PM
T-1000's Avatar
R150F vs R154
Do they have the same bolt patterns engine side?
Also, is the 1UZFE a wet or dry sleeve engine? I haven't been able to find a rebuilding kit for one yet...
Old Jan 27, 2009 | 06:53 PM
7m4x4dude's Avatar
as far as i know the r154 has the bolt pattern from the M series engine's, you can purchase a jdm/oem bellhousing to fit 1jz/2jz n/a &turbo engines.
the r150 is from the 3.0 v6 iirc, and the r151 is the turbo truck tranny, which is an R series engine.
Old Jan 27, 2009 | 07:09 PM
T-1000's Avatar
Actually what I should have asked is if the R151F and R154 have the same engine side bolt pattern on the bell housing...
Old Jan 27, 2009 | 07:34 PM
7m4x4dude's Avatar
i think i awnsered that, the r150 was a R series engine mating bell, the r151f is a 3.0 3vze mounting engine bellhousin, and the 154 mount's to all M series engine's.
so short awnser is no, the r154 bell will not bolt onto either the 4cly, nor the v6 engine's.
Old Jan 28, 2009 | 06:23 PM
toyminator2000's Avatar
Try www.lextreme.com. They sell all sorts of parts.
Their forum also has tons of info on the 1UZFE swap.
Old Jan 28, 2009 | 09:07 PM
[N8]'s Avatar
Yes, the 150 & 154 have the same bellhousing-side bolt pattern. 154 input shaft is longer though.
Swim
9
Jan 4, 2016 10:47 AM
skypilot
Aug 25, 2015 01:09 PM
TheManOutside
Jun 18, 2015 03:32 PM
JamesD
Sep 13, 2008 07:43 PM
mfxsupervillain
Nov 21, 2006 05:19 PM
