Spider gears?
Old Feb 2, 2009 | 07:53 AM
pitster33's Avatar
Spider gears?
Last weekend I was trying to climb a big hill and after about the 6th attempt I heard some snapping from the front drivers side and my four wheel drive stoppped working. So I tore the front end apart because the cv's and hubs were fine. I found that the spider gears were just shreded. I have a complete front third member from a 4cylinder with 4.10s but my truck is a 3.0 and the gears are different. But my question is are the spider gears the same on a 3.0 and a 4 cylinder?
Old Feb 2, 2009 | 09:34 AM
WFO's Avatar
WFO
I dont belive they are the same. What gear ratio is your truck? You can put the V6 third in the front end with no modifications.
Old Feb 2, 2009 | 08:31 PM
Jay351's Avatar
I thought all 7.5" diffs where the same?
Old Feb 2, 2009 | 09:25 PM
notanymore's Avatar
yeah on the front im pretty sure they are the same, but they are different in the rear.
Old Feb 3, 2009 | 04:33 AM
WFO's Avatar
WFO
7.5?? I thought we were talking about the solid axle 8". If it is the IFS diff I couldnt tell ya
Old Feb 3, 2009 | 07:36 AM
Trustyrusty's Avatar
Time to lincoln lock the front!
Old Feb 4, 2009 | 11:30 AM
pitster33's Avatar
Thanks for the help! I ended up countin my stock gears and it turns out they were 4.10's so I swapped the whole front 3rd member from the 4 cylinder into my v6 and my 4wd is working great. I am kind of dissapointed that I didnt have the 4.56's that I thought I had but I can pull my 33 12.50s good so Im not to worried about it. Plus I can get whole 3rd's with 4.10s for $20 any time so if I break a diff again I can fix it easy and dirt cheap.
Old Feb 4, 2009 | 03:04 PM
LTrunner's Avatar
i don't think that you can re-use/ mix macth v6 3rd and 4cly 3rd parts. the v6 one is bigger and beffier and has 4 spiders where the 4cly has 2. i believe that the v6 spiders are smaller than the 4cly ones
Old Feb 5, 2009 | 03:45 PM
pitster33's Avatar
you are correct about the 4 spider gears on the v6 but thats only in the rear end, the 4 cylinder and v6 share the same 7.5" front diff.(to the best of my knowledge)
Old Feb 6, 2009 | 10:11 AM
b/s rules's Avatar
x2 with trusty rusty, but be prepared to lose your turning ability in 4wd. i just leave my drivers side hub unlocked to steer, then lock it in when things get ugly or on its side
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
