Waterless antifreeze, I use it, anyone else?
Old Jan 31, 2009 | 11:14 PM
harrywat's Avatar
I started using Evans Waterless Antifreeze over six years ago and I have it in everything but my wife's Lexus, its next.
It boils at 375 *F, never has to be replaced, is good down to -70*F, then it contracts. Not harmful to animals, prevents cavitation.
I love the old Mercedes diesels from the 80s, I still have three. The 86-87 300 SDL engine is like our 3vx, likes to blow head gaskets. While mine was still good, I put in the Evans, six years later and maybe 100K more miles, I'm still good.
The day I installed it, I took the car on a 20 mile I-20 run, pulled off on a ramp and removed the radiator cap, all I got was a weak ptzzz. You can run with the cap loose and even without a cap if that's what you wanted, although I have not done so.
Anyone else out there using it?
Harry
Old Jan 31, 2009 | 11:45 PM
24Runna's Avatar
Never heard of it. I stick to OEM generally.
Old Jan 31, 2009 | 11:54 PM
24Runna's Avatar
Found a thread.
https://www.yotatech.com/forums/f123...oolant-114994/
Old Feb 1, 2009 | 04:54 AM
X-AWDriver's Avatar
I heard of the stuff but I'm in no hurry to change mine but I will be paying attention to how the stuff does in more and more real world applications as more people start to use it.
Old Feb 1, 2009 | 07:43 AM
harrywat's Avatar
Originally Posted by 24Runna
Thanks for the thread. With the links there, its hard read all of that and not want the stuff in your engine.
I put a new radiator hose on my SDL when I first started using NPG+ and it still holds the original shape, no ballooning.
Harry
Old Feb 1, 2009 | 07:55 AM
mt_goat's Avatar
I'm still using it. I like that I never have to worry about boiling-over or hot spots on the head surface causing detonation or rust & corrosion in the cooling system. My only complaints are the initial cost of it, and it would be hard to find replacement coolant on the road if you ever sprang a leak. As a result I carry an extra gal with me all the time.
I've developed some good techniques for catching it, and reusing it when I change the t-stat or radiator or for some other reason have to drain the coolant.
The catching part:
Then before going back in I filter it in case some dirt dropped in:
Old Feb 1, 2009 | 08:17 AM
harrywat's Avatar
Thanks Dale, I'll follow suit when needed.
I appreciated reading about the extensive research you did on NPG+ before using it, good information.
Harry
Old Feb 1, 2009 | 08:18 AM
Belize Off Road Team's Avatar
I am going to use Prestone pre-diluted antifreeze when i do the 3.4L swap
Old Feb 1, 2009 | 08:27 AM
slosurfer's Avatar
Wish I had known about this stuff when I went through the cooling system on my van or when I did the timeing belt on the 4runner.
They both have toyota red now, so I'll keep an eye on this stuff. I think it costs about what a gallon of toyota red does at the dealership.
Old Feb 1, 2009 | 09:02 AM
874runnersr5's Avatar
hmm makes me want to try it out.
Old Apr 23, 2009 | 09:54 PM
mrddk92's Avatar
i want to get some also. I think that just the fact that there is less pressure would make it way harder too spring a leak...
Old Apr 23, 2009 | 10:04 PM
stagger_lee's Avatar
I'll be using it when I swap in my new motor in a couple weeks. Read nothing but good things.
Old Apr 23, 2009 | 11:33 PM
turborich's Avatar
I have never used it but have only heard great things about it on several sites.
Old Apr 23, 2009 | 11:41 PM
spanish-road's Avatar
i use distilled water in the summer.
Old Apr 24, 2009 | 12:00 AM
toyota4x4907's Avatar
ONLY water?
Old Apr 24, 2009 | 07:00 PM
marko3xl3's Avatar
Originally Posted by toyota4x4907
ONLY water?
Water conducts/dissipates heat A LOT better than a 50/50 mix.
The only reason we use coolant/antifreeze is to increase the boiling point of the liquid and decrease the freezing point.
Modern engines run really close to 200-210 degrees (which is normal by today's standards) and can even reach "safe" temps of 220-225 during hot summer days, long idling etc. Since water boils at 212 degrees, it would easily boil under those conditions which we don't want and that's why antifreeze is in use today.
Old Apr 24, 2009 | 07:11 PM
Keyser Söze's Avatar
There's also the anti-corrosion properties of using coolant to be considered.
Old Apr 24, 2009 | 09:21 PM
turborich's Avatar
not only that but it also helps to lubricate the water pump. You can run distilled water but should run at least 20% coolant just to be safe.
Old Apr 24, 2009 | 09:50 PM
corax's Avatar
What are you lubricating in the water pump? the sealed bearings full of grease? or the seals which shouldn't let any coolant past anyway?
I've looked at NPG, and while it sounds good, distilled water still has the highest "specific heat" of anything you can run in an engine (heat transfer ability). That and I worry about what happens if I need to top off while on the road.
before anyone tries to convince me otherwise with a well worded marketing schpeel, I already read it on their site. If I had a perfectly sealed system I might give it more thought.
yourrealdad
7
Jul 21, 2015 08:53 AM
kcaudill
Jul 20, 2015 12:06 PM
Jonny246
Jul 12, 2015 04:51 AM
cracker_1
17
Jan 14, 2006 12:50 PM
