a long last...
Old Feb 1, 2009 | 12:57 PM
iamsuperbleeder's Avatar
at long last...
I installed my t-stat housing temp-probe mod this weekend
horrible camera-phone pics, I know... but there's not a whole lot to take pictures of really
and I just realised the thread title is missing a letter... it reads "a long last", it's suppose to say "at long last"... mod, please change?
Old Feb 1, 2009 | 01:02 PM
Jay351's Avatar
Sweet! I got my guage pillar, now I need guages
Old Feb 1, 2009 | 01:08 PM
if I had to do it again, I'd pony up the dough and get full electric gauges... it'll make the install a lot easier...
maybe I'll upgrade later on, but I just thought I'd throw that out there
Old Feb 1, 2009 | 01:43 PM
scuba's Avatar
I would if I could......
Old Feb 1, 2009 | 01:55 PM
Jay351's Avatar
Im defantly going electric. But i probibly won't be able to afford the autometer gauges I want ($200 a pop ). I will probibly go with a cheaper electric. Still not %100 on the last guage I want to run ( temp, oil pressure and.....?).
Old Feb 1, 2009 | 02:40 PM
yeah, a lot of gauges are freek'n outrageously expensive for some reason... I don't get it...
Old Feb 1, 2009 | 02:48 PM
874runnersr5's Avatar
oil temp?
Old Feb 1, 2009 | 03:02 PM
BigBluePile's Avatar
Go with VDO gauges:
These are less the $30 a piece and work great! They're electrical too, but you have to buy senders seperately. Simple, effective and work great in your a-pillar pods.
Bleeder it looks great!!!!
Old Feb 1, 2009 | 04:17 PM
you guys ever seen the guages where you pretty much design the guage on your computer with a usb cord? its insane haha, you can do so many things
Old Feb 1, 2009 | 05:26 PM
Jay351's Avatar
Originally Posted by 874runnersr5
oil temp?
I dunno if I really need that.. Water temp should be good enough right?
Go with VDO gauges:
I kinda wanted full sweep guages... And the temp needs to be in celcius.. Im canadian I can't understand your funky temp measuring system..
Old Feb 1, 2009 | 05:42 PM
Hayes's Avatar
go voltmeter. Monitor your charging system and know if there is a problem before you get totally drained.
I run volts, oil pressure and trans temp (auto trans). When I get to feeling like I need more than the stock temp gauge I can run another sensor through a dual switch and swap back and forth between trans temp and coolant temp.
Old Feb 1, 2009 | 06:40 PM
Check here: http://www.egauges.com/VD2_main.asp
Like this:
Old Feb 1, 2009 | 06:43 PM
Volt meters are pretty basic, but if you really want to see how your charging system is working use an ammeter.
Old Feb 1, 2009 | 07:45 PM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
22r oil sending thread pitch is retarded, none of the adapters that come with sunpro, FAZE, or anything are a direct fit, apparently autometer has the right adapter? this is my hold up.
Old Feb 1, 2009 | 07:48 PM
hmm good point, if i only had a turbo i could have a boost guage =(
Old Feb 1, 2009 | 07:59 PM
annoyingrob's Avatar
Threadjack
Oil Pressure, Boost, and EGT. Not pictured, on the other side of the steering wheel are water temp, and fuel pressure. All electronic peak and hold
Old Feb 1, 2009 | 08:19 PM
Jay351's Avatar
crazy lookin interior!
Old Feb 1, 2009 | 09:32 PM
seriously... what am I looking at???
Old Feb 1, 2009 | 09:36 PM
myyota's Avatar
not sure what it is, but i would say its right hand drive, by the picture.
Old Feb 1, 2009 | 09:38 PM
maybe the Supra in his sig???
