87 22rte NO start after rebuild!
Old Feb 1, 2009 | 04:34 PM
64-Hurricane's Avatar
I just finished an HG replacement that ended up being a total head rebuild and timing component replacement. After getting it all sealed up I've been having starting issues. I got the timing down, I've got good compression, good spark with popper gap, new gas in the tank, good fuel pressure and I have fuel at the cold start injector. But I am NOT getting fuel in the combustion chamber.
I pulled the plugs after some serious cranking and the plugs as well as cylinders were bone dry. I sprayed some starting fluid through a vacuum port into the manifold, and after some short cranking she immediately caught but died as soon as it consumed the fluid.
What should I check that could be causing the injectors to not fire? The truck WAS an automatic and has been changed to a manual. Other than that, the engine/electronics are stock.
Old Feb 1, 2009 | 04:43 PM
85TurboRunner's Avatar
Is the fuel pump working? nevermind I guess I should learn to read.
Old Feb 1, 2009 | 04:51 PM
Haha, I ts all good. I should have included a cliff's notes version!
From my investigation, EVERYTHING is working except for the injectors. Either the injectors themselves are bad, or I have messed up some part of the wiring.
I mean, what sensors, safety checks etc could cause the injectors to not fire but allow the engine to crank?
Old Feb 12, 2009 | 11:23 AM
400yzturbo's Avatar
How long was the truck sitting during rebuild? I rebuilt a 22rte and then it wouldn't start and i sprayed a little starting fluid down it and it did the same thing. It turned out my injectors weren't spraying for some reason. I replaced them and it fired right up.
Old Feb 12, 2009 | 12:30 PM
tampabayota's Avatar
check grounds
Old Oct 6, 2010 | 02:03 PM
Double D's Avatar
Was this problem resolved? And was it new injectors or grounds?
bigjstang
Jun 2, 2025 03:56 PM
jerusry
Oct 19, 2015 05:28 PM
Yota.Jay
Jul 23, 2015 08:08 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
karbin
Jul 5, 2015 11:37 PM
