loss of power when it rains????? HELP
Old Oct 4, 2010 | 05:46 PM
masonsdad09's Avatar
Lightbulb loss of power when it rains????? HELP
i have a 89 toyota 4x4 22re 5 speed cap,rotor,wires,plugs are all new a month ago when it rains or is really damp out i dont have much power till i hit about 4000rpm then its like somone rearended my truck and it takes off like a raped ape but it only does this when it rains any ideas???????
Old Oct 4, 2010 | 06:01 PM
BajaRunner's Avatar
I've heard about O2 sensor wiring getting wet causing problems. Other than that I don't know. Make sure that harness is dry and get it out of any wet areas. Maybe wrap with some electrical tape?
Old Oct 4, 2010 | 09:21 PM
Elton's Avatar
could be moisture getting in the cap
Old Oct 5, 2010 | 03:56 AM
i have sprayed wd40 in the cap and no change wouldnt wd40 displace any moisture
Old Oct 5, 2010 | 06:58 AM
clydehatchet's Avatar
wd40 would help quite a bit if that was a problem, also try putting dielectric grease in your plug wire boots. with something like this, your only choice is to just do one thing at a time till you nail it, as frustrating as it is.
Old Oct 5, 2010 | 07:08 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
What the heck? Where is the other thread titled JUST LIKE THIS ONE?
I know there is one, cause I posted in it.
Old Oct 5, 2010 | 07:14 AM
Unhappy
this problem is even more frustrating for me cause at the moment 3rd gear is out of my tranny and it really hard to get going lol
Old Oct 5, 2010 | 07:22 AM
Oh, you mean this one. https://www.yotatech.com/forums/f116/3-0-rain-221104/
Old Oct 5, 2010 | 07:35 AM
Unhappy
sorry mine is a constant sputter till i hit about 4000rpm and then bam
Old Oct 5, 2010 | 01:37 PM
drove the truck today and it was fine till i got about 2 miles down the road and started again
Old Oct 5, 2010 | 01:50 PM
Elton's Avatar
i sure hope u didn't use bosch wires or plugs
Old Oct 5, 2010 | 02:08 PM
idk about the plugs but i know the wires arnt
Old Oct 5, 2010 | 02:15 PM
nlinn's Avatar
i've always heard that Bosch were good.
what's wrong with them?
(not that I'm partial to any particular brand, I don't have any experience in this area and am just curious)
Old Oct 5, 2010 | 06:28 PM
richf's Avatar
bosch is a good brand but they just don't work well with toyotas from what I have read. NGK or Denso is the way to go.
Old Oct 6, 2010 | 04:09 AM
no bosch here lol
Old Oct 6, 2010 | 02:11 PM
Argento102's Avatar
Yep, the pick-ups INSIDE the distributor have went south and are
picking up the ambient moisture in the air. Toyota service in Japan
did a bulletin EVER ago on it. I had the exact issue in my 93" 4R.
It felt like the ignition was kickin in / out then BOOM it would accelerate.
Those pick-ups aren't replaceable either. Look for a another distributor.
Old Oct 6, 2010 | 02:17 PM
will have to try that along with a new coil and distributor cap
Sleaker
Aug 26, 2020 06:03 AM
4.34runner88
Aug 11, 2018 10:44 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
gmonnie123
Jul 26, 2015 02:44 PM
