90 pickup firewall issue..
Old Jan 30, 2009 | 11:12 PM
LilPyke's Avatar
ok so on my truck when i push in the clutch it seems the whole clutch bracket moves in. i looked around and when i push the clutch in the bracket moves in too and under the hood the slave cylinder moves back. (towards the cab) i think it the firewall is weak or something cause the metal like bends in and idk what to do makes my truck nearly impossible to drive. i was thinkn bout putin a peice of metal behind the slave cylinder to make the spot stronger buy idk if thatll do anything. anybody else know what to do or no similar problems?
Old Jan 30, 2009 | 11:28 PM
Elton's Avatar
sounds like your clutch bracket cracked theres a few threads some where about this
Old Jan 30, 2009 | 11:31 PM
mudcrasher's Avatar
is the firewall rusting? where do you live? is rust an issue where you are? friend of mine had a chevy pu that when you pushed in the clutch the cab would lift off the frame. ate a few clutches in under a few thousand miles and he decided to swap the cab. might be easier to swap the cab if the firewall is .
kazuya2416
Apr 5, 2024 02:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
