Someone PLEASE HELP.. solenoid problem...
Old Feb 3, 2009 | 07:33 AM
creeper's Avatar
Unhappy Someone PLEASE HELP.. solenoid problem...
Here's my problem...
I am wondering which color (black,white,or yellow) wire goes to the No. 2 solenoid in the transmission. BTW 1994 V6 AT 4wd 4runner. thanks a million, Lyle
One person says its the black wire, while another person says its the yellow wire.
Which one is it, please help, its cold out, and I'm tired of walking around this town....
Old Feb 3, 2009 | 07:51 AM
22mr2's Avatar
do you know what the #2 solenoid does? Looked at a wiring diagram and cant seem to find it. Is it on transmission or transfer case?
Old Feb 3, 2009 | 07:52 AM
DeathCougar's Avatar
The only way to know for sure is to check a wiring diagram. There are 20 miles of wiring in any given vehicle, its nearly impossible for anyone....even myself ......to know what color ONE wire in the loom is.
Old Feb 3, 2009 | 07:54 AM
desconhecido's Avatar
Here's a reference to the same diagram you posted but it has the colors labeled:
didnt.doit.wisc.edu/offroad/Toyota/manuals/ileaf/95toyrm/95toypdf/95rmsour/1995/954runne/at2/valvebod.pdf
I don't know if this will give you what you need or not -- it doesn't identify which solenoid is which, just identifies which colored wires go where.
It appears in the FSM that the wire from the ECU to the #2 solenoid is black. Which wire that connects to inside the transmission, I'm not sure. Can you tell by inspecting the connectors?
I apologize for misinterpreting your original questiion -- I thought you were asking about the vehicle wiring harness wire color -- which the FSM seems to identify.
Old Feb 3, 2009 | 07:55 AM
mt_goat's Avatar
This wiring diagram shows 2 wires going to the #2 solenoid. http://www.ncttora.com/fsm/1990-1995...stemci/ect.pdf
It looks like to me one is solid black and one is red with a white stripe, but I'm not very good at reading EWDs.
Old Feb 3, 2009 | 08:20 AM
That diagram shows two wires -- one for each case:22RE, 3VZ-E. With the 22RE, the wire is red with white, for the 3.0, the wire is black.
Old Feb 3, 2009 | 08:27 AM
mt_goat's Avatar
Thank you for clairifing that.
chuckross1957
Jun 28, 2019 10:19 PM
Longbed 90
Oct 19, 2015 11:05 AM
pickle6415
Oct 19, 2015 08:08 AM
toyhaulert100
Sep 24, 2015 07:55 PM
themightykhoner
Sep 18, 2015 02:28 AM
