22re EGR block off
Old Sep 12, 2008 | 04:29 PM
94yota05gto's Avatar
22re EGR block off
i figured while i had the motor out i would do the egr block off. i dont like the way the cover plates turned out so i might end up changing them, but any way are these the only parts that need to be removed? ( i still have to plug all the vac lines on the throttle body)
these pics are how the intake looks now
these are the 3 block off plates (i forgot to take a pic of the block off plate on the head)
Old Sep 12, 2008 | 08:58 PM
i have done a search and found some things but im getting a little confused with it all. what else needs to be done. anyone??????
Old Mar 10, 2009 | 07:08 PM
KODE's Avatar
bump this up for more info.....
Old Mar 10, 2009 | 08:09 PM
abecedarian's Avatar
looks like you also removed the vacuum line for the fuel pressure regulator, the charcoal canister purge, the PAIR valve and some other things in there too.
Old Mar 11, 2009 | 06:29 AM
myyota's Avatar
Like said above, your going to need some of the vacuum lines that you removed for the engine to run right.
montanatruck
Feb 26, 2017 07:07 AM
Dakotaneu
Jul 27, 2015 12:03 AM
montanatruck
Jul 25, 2015 03:45 AM
kcaudill
Jul 20, 2015 12:06 PM
