Top Tranny Bolts
Old Jan 13, 2009 | 07:20 PM
91Toyota's Avatar
Top Tranny Bolts
There are two of them on the back of the engine on the top. How the heck do you get these suckers out? I even bought a ratcheting wrench and it still didn't help.
I'm thinking about taking off the engine mounts and moving it forward and then taking them off...suggestions?
Thanks, Trevor
Old Jan 13, 2009 | 07:24 PM
abecedarian's Avatar
Old Jan 13, 2009 | 07:27 PM
91Toyota's Avatar
Jeez, now if only I would have seen that years ago. I already spent $19 on a wrench. lol
Old Jan 13, 2009 | 07:30 PM
tc's Avatar
tc
1 mile of extensions, some wobble, some normal
I posted that image a while back on a thread asking the same question.
Anyone ever tell you to use the search function?
Old Jan 13, 2009 | 07:31 PM
Are we talking about tools or hair-weaves?
Old Jan 13, 2009 | 07:32 PM
InternetRoadkill's Avatar
Drop the rear crossmember a few inches using a jack. They can be reached easily then using about 3' of extensions.
Old Jan 13, 2009 | 07:33 PM
DirtNWaterMakeMUD's Avatar
you can do it with a few extentions and at the last extension use a flexable socket adaptor, cheaper than a new wrench
Old Jan 13, 2009 | 07:37 PM
If you go the extension route... add "one friend to help put the socket back on the bolt when it pops off".
And I don't know about the cost thing- that ratchet cost me about 15 bucks at a home depot a while back. By the time you buy a few extensions and either a u-joint or wobble socket it's about the same. Plus I find myself using that ratchet for other things like when something's in the way and can't get a straight pull on a regular ratchet.
Old Jan 13, 2009 | 08:09 PM
Asha'man's Avatar
I can do it with a 12" extension, a 6" extension, and a U-joint. And a regular ratchet.
Old Jan 13, 2009 | 08:23 PM
95RunnerSR5's Avatar
call me special but i did it twice with a gear wrench. i had the tire off, and facing to the front of the truck i slid sideways between the wheel hub and fenderwell and stuck my arm out to reach lol..... worked pretty good
Old Jan 13, 2009 | 08:53 PM
86tuning's Avatar
A transmission shop would drop the trans crossmember enough to allow a 24" extension and a 17mm swivel socket, and hit it with an impact wrench.
You can do the same with an 18-24" extension and a big ratchet, plus a universal adapter and socket.
Old Jan 13, 2009 | 09:07 PM
scuba's Avatar
I notice that wrench...
Old Jan 13, 2009 | 09:20 PM
85TurboRunner's Avatar
I've always used a wrench. Never had a problem with them.
Dieselmann
Feb 19, 2019 02:57 AM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
Cdn-wilderness
Jul 10, 2015 07:43 PM
madxman21
Jul 9, 2015 10:26 AM
