93 4runner transfer binds...
Old Jan 11, 2009 | 07:15 PM
DesertWind's Avatar
Need some help guys, I recently purchased a 93 SR5 4Runner w/3.0 & 5-Spd. Previous owners had Grenaded the front differential, I purchased a nice used unit and installed it today. The new diff works well, but now when in 4wd "on dirt" the tires (front-back) seem to want to drag, they will continue to "skip" drag even with the clutch engaged. Once taken out of 4wd no problems. I have lifted the truck completely off the ground and in 4wd (running) and does not produce any thing noticeable going on...) Even through the complete gear ranges 4L-4H and 1st.-5th. gear. Any input to this matter would be greatly appreciated. The fun of buying used trucks right?
Old Jan 11, 2009 | 07:19 PM
85TurboRunner's Avatar
Are the gear ratio's the same?
Old Jan 11, 2009 | 07:25 PM
DeathCougar's Avatar
You didn't match gear ratios. It has nothing to do with the trans or case. You will need to A. get a matching ratio diff for the front, or B. Pull the cover off the front diff, count the teeth, and get the proper matching rear diff.
Old Jan 11, 2009 | 07:26 PM
DesertWind's Avatar
Well from the factory code label on the door I had a 4.56 I confirmed this by counting the ring and pinion, the new one is a 4.88 AT/Gears figured close to try... I did make the purchase of the rear 3rd. member at the same time...)
Old Jan 11, 2009 | 07:55 PM
DesertWind's Avatar
Here shortly I'm going out to the shop and count the rear 3rd. member to see if they correspond. I know from the older gentlemen that the truck had never been changed, It was totaled from the side...)
Old Jan 11, 2009 | 08:15 PM
If you have one with a 4.56, and the other diff with a 4.88, there is your problem. You have to have the exact same diff ratios.
Old Jan 11, 2009 | 08:23 PM
DesertWind's Avatar
Yes, You are correct... Just counted the 3rd. member that I purchased along with the front housing and it's a 4.88 also... So tommorrow I will drop in the rear 3rd member and go from there...) Thanks for the help guys I will post back once completed...
Old Jan 12, 2009 | 01:01 PM
DesertWind's Avatar
Well guy's just finished dropping in the 4.88 rear 3rd. member and took it to the desert and rolls out just fine in all ranges...) Being I just purchased this truck and never able to try the 4wd. (being they Grenaded) the intermediate shaft clutch hub assembly on the A.D.D. Really did not know how much further I needed to go. Later on I will rebuild the front assembly for an extra to have on hand. Got lucky being I only paid $125.00 for the front diff/rear 3rd. I installed new half shafts at the same time. Well guys I Thank you and it's great to have friends you can count on! and Thanks for having me aboard...)
Steve~
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Tykiller1994
Aug 10, 2015 07:49 PM
crashburnoveride
Jul 10, 2015 06:39 AM
